メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PowerBook G3 Wallstreet Display Replacement
必要な工具と部品
    1. PowerBook G3 Wallstreet Display Replacement, Keyboard: 手順 1、 1の画像 1
      • Remove both expansion bay modules using the levers on the front of the computer.
      • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
      • Pull the tabs toward yourself and the keyboard will pop up.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G3 Wallstreet Display Replacement: 手順 2、 1の画像 1
      • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
      • Rest the keyboard on the trackpad.
      FixBotに聞いてみる
      コメントを追加
      • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
      • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
      • 2) After disengaging the locking bar, slide the cable out of the connector.
      FixBotに聞いてみる
      コメントを追加
    3. PowerBook G3 Wallstreet Display Replacement: 手順 4、 1の画像 1
      • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
      FixBotに聞いてみる
      コメントを追加
    4. PowerBook G3 Wallstreet Display Replacement: 手順 5、 1の画像 1
      • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
      • Once the strain relief cables are free, lift the keyboard off.
      FixBotに聞いてみる
      コメントを追加
    5. PowerBook G3 Wallstreet Display Replacement: 手順 6、 1の画像 1
      • Your laptop should look approximately like this.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G3 Wallstreet Display Replacement, Heat Shield: 手順 7、 1の画像 1
      • Remove the two Phillips screws from the heat shield.
      • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G3 Wallstreet Display Replacement: 手順 8、 1の画像 1
      • Grasp the metal handle on the heat shield and pull up and toward yourself.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G3 Wallstreet Display Replacement, Hard Drive: 手順 9、 1の画像 1
      • Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G3 Wallstreet Display Replacement: 手順 10、 1の画像 1
      • Grasp the hard drive bracket on the left side and pull up and to the left.
      FixBotに聞いてみる
      コメントを追加
    3. PowerBook G3 Wallstreet Display Replacement: 手順 11、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G3 Wallstreet Display Replacement, Processor: 手順 12、 1の画像 1
      • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
      • Remove the processor by sliding it up and to the right.
      • The processor and RAM can be removed as a unit. It is not necessary to remove the RAM from the processor.
      • There are two tabs on the left side of the processor that fit into slots on the metal framework. Make sure these tabs are in the slots.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G3 Wallstreet Display Replacement, Modem: 手順 13、 1の画像 1
      • Remove the single Phillips screw from the modem.
      • Disconnect the orange PMU cable by pulling it directly up.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G3 Wallstreet Display Replacement: 手順 14、 1の画像 1
      • Disconnect the modem from the logic board by lifting up on the right side using a spudger, the tip of your finger, or a flat non-metal tool.
      • Remove the modem by sliding it up and to the right.
      FixBotに聞いてみる
      コメントを追加
    3. PowerBook G3 Wallstreet Display Replacement: 手順 15、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G3 Wallstreet Display Replacement, Clutch Cover: 手順 16、 1の画像 1
      • Push the display back so that it lies flat.
      • Slip a spudger or your index finger under the clutch cover near the power button and pull upward until you feel it come free.
      • Repeat the previous step on the left side.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G3 Wallstreet Display Replacement: 手順 17、 1の画像 1
      • Lift the clutch cover off by rotating it up and then toward you.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G3 Wallstreet Display Replacement, Display: 手順 18、 1の画像 1
      • Disconnect the orange display data cable on the left side of the computer. Grasp the cable near the connector and pull directly up.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G3 Wallstreet Display Replacement: 手順 19、 1の画像 1
      • Disconnect the orange display inverter cable on the right side of the computer. Grasp the cable near the connector and pull directly up.
      • Make sure that both cables are free from the plastic casing before proceeding to the next step.
      FixBotに聞いてみる
      コメントを追加
    3. PowerBook G3 Wallstreet Display Replacement: 手順 20、 1の画像 1
      • Turn the laptop around so that its back faces you.
      • Open the port door located at the back of the laptop.
      • Remove the four black T8 Torx screws.
      FixBotに聞いてみる
      コメントを追加
    4. PowerBook G3 Wallstreet Display Replacement: 手順 21、 1の画像 1
      • Turn the laptop back around so that the screen faces you.
      • Adjust the display so that it is in a vertical position.
      • Hold the display on both sides and pull directly up until its hinges are free of their mounts
      FixBotに聞いてみる
      コメントを追加
    5. PowerBook G3 Wallstreet Display Replacement: 手順 22、 1の画像 1
      • Your laptop should look like this.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
8 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 16
過去 30 日: 67
今までの合計 9,979
