はじめに
How to access the PowerBook G3 Wallstreet Clutch Cover.
必要なもの
Remove both expansion bay modules using the levers on the front of the computer.
Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
Pull the tabs toward yourself and the keyboard will pop up.
Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
Remove the processor by sliding it up and to the right.
Remove the single Phillips screw from the modem.
Disconnect the orange PMU cable by pulling it directly up.
Push the display back so that it lies flat.
Slip a spudger or your index finger under the clutch cover near the power button and pull upward until you feel it come free.
Repeat the previous step on the left side.
15 の人々がこのガイドを完成させました。
