メインコンテンツにスキップ
  1. この手順は未翻訳です。 翻訳を手伝う。
    Turn the keyboard locking screw so that it is parallel to the space bar.
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
  2. この手順は未翻訳です。 翻訳を手伝う。
    Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
    • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
  3. この手順は未翻訳です。 翻訳を手伝う。
    Your laptop should look approximately like this.
    • Your laptop should look approximately like this.
  4. この手順は未翻訳です。 翻訳を手伝う。
    Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Lift the heat shield up and pull it toward you.
  5. この手順は未翻訳です。 翻訳を手伝う。
  6. この手順は未翻訳です。 翻訳を手伝う。
    Skip this step if your computer does not have an Airport card installed.
    • Skip this step if your computer does not have an Airport card installed.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
    • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
  7. この手順は未翻訳です。 翻訳を手伝う。
    Disconnect the antenna cable from the Airport card.
    • Disconnect the antenna cable from the Airport card.
  8. この手順は未翻訳です。 翻訳を手伝う。
    Pull the battery cable directly up from the logic board.
    • Pull the battery cable directly up from the logic board.
    • Remove the battery from its holder by pulling up and to the left.
  9. この手順は未翻訳です。 翻訳を手伝う。
  10. この手順は未翻訳です。 翻訳を手伝う。
    Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
  11. この手順は未翻訳です。 翻訳を手伝う。
    Lift the heat sink up from the left side and pull it out.
    • Lift the heat sink up from the left side and pull it out.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
  12. この手順は未翻訳です。 翻訳を手伝う。
    Grasp the plastic tab on the processor's right side and pull it directly up.
    • Grasp the plastic tab on the processor's right side and pull it directly up.
    • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
  13. この手順は未翻訳です。 翻訳を手伝う。
ゴール
8 の人々がこのガイドを完成させました。
添付文書
iRobot
メンバー登録日: 2009年09月24日
1 ポイント
647のガイドは作成済み
コメント1件
i know how to fix the processor but i have heard of much more powerful upgrades
Roman - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 8,569
