メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PowerBook G3 Pismo PRAM Battery Replacement
必要な工具と部品
    1. PowerBook G3 Pismo PRAM Battery Replacement, Keyboard: 手順 1、 1の画像 1
      • Turn the keyboard locking screw so that it is parallel to the space bar.
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G3 Pismo PRAM Battery Replacement: 手順 2、 1の画像 1
      • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
      • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
      • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
      FixBotに聞いてみる
      コメントを追加
    3. PowerBook G3 Pismo PRAM Battery Replacement: 手順 3、 1の画像 1
      • Your laptop should look approximately like this.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G3 Pismo PRAM Battery Replacement, Heat Shield: 手順 4、 1の画像 1
      • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
      • Lift the heat shield up and pull it toward you.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G3 Pismo PRAM Battery Replacement: 手順 5、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G3 Pismo PRAM Battery Replacement, Airport Card: 手順 6、 1の画像 1
      • Skip this step if your computer does not have an Airport card installed.
      • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
      • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G3 Pismo PRAM Battery Replacement: 手順 7、 1の画像 1
      • Disconnect the antenna cable from the Airport card.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G3 Pismo PRAM Battery Replacement, PRAM Battery: 手順 8、 1の画像 1
      • Pull the battery cable directly up from the logic board.
      • Remove the battery from its holder by pulling up and to the left.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G3 Pismo PRAM Battery Replacement: 手順 9、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
27 の人々がこのガイドを完成させました。
添付文書
作成者
2人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
6件のガイドコメント
Frankly speaking I do not have idea why do I need steps 2-7 to replace battery? Why I can't go directly to step 8 if it is possible? BTW - the battery seems to be composed from 4 standard batteries. Is anyone aware how to assembly new battery? It is not available as spare part (616-0108)
Tomek - 返信 共有
Agreed, I just successfully removed my PRAM battery skipping all those steps, just popped the keyboard out, removed the DVD drive from the right-hand out and popped that bad boy out, no problemo.
Edward Gain - 返信 共有
I read that you "removed the DVD drive from the right-hand out...." I'm baffled as to what you mean or how that is done. Can you explain that step?
Scott Kohanek - 返信 共有
Why do I need to remove the airport card? It's just like telling somebody to remove their shoes to take off their hat?
christopher Ng - 返信 共有
Wish I had read the comments before proceeding. Just removed the Airport card and put it back in for no reason. Thanks for the instructions though.
j.boersma - 返信 共有
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 21
過去 30 日: 91
今までの合計 42,242
