この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
How to remove the hard drive, along with its cable and bracket from your computer.
必要な工具と部品
Turn the keyboard locking screw so that it is parallel to the space bar.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
Lift the heat shield up and pull it toward you.
Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
Remove the long silver Phillips #1 screw from the heat sink.
Remove the two T8 Torx screws that attach the heat sink to the processor.
Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
4 の人々がこのガイドを完成させました。
