この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Changing the top case will also give you a new trackpad.
必要な工具と部品
Turn the computer so that the ports are facing you.
If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
Grasp the orange display data cable and disconnect it from the logic board.
Pull the display cable straight up so that it is vertical.
Turn the laptop around so that its back faces you.
Open the port door located at the back of the laptop.
Remove the four black Torx screws.
Remove the three long silver and two short black Torx screws from the beige plastic casing.
3 の人々がこのガイドを完成させました。
