メインコンテンツにスキップ
PowerBook G3 Lombard RAM Replacement
必要な工具と部品
  1. PowerBook G3 Lombard RAM Replacement, Keyboard: 手順 1、 1の画像 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard RAM Replacement: 手順 2、 1の画像 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard RAM Replacement: 手順 3、 1の画像 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard RAM Replacement, Heat Shield: 手順 4、 1の画像 1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. PowerBook G3 Lombard RAM Replacement: 手順 5、 1の画像 1
    • Lift the heat shield up and pull it toward you.
  6. PowerBook G3 Lombard RAM Replacement: 手順 6、 1の画像 1
    • Your laptop should look approximately like this.
  7. PowerBook G3 Lombard RAM Replacement, PRAM Battery: 手順 7、 1の画像 1
    • Pull the battery cable directly up from the logic board.
  8. PowerBook G3 Lombard RAM Replacement: 手順 8、 1の画像 1
    • Remove the battery from its holder by pulling up and to the left.
  9. PowerBook G3 Lombard RAM Replacement, Modem: 手順 9、 1の画像 1
    • Remove the two silver Phillips screws from the modem.
  10. PowerBook G3 Lombard RAM Replacement: 手順 10、 1の画像 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
  11. PowerBook G3 Lombard RAM Replacement: 手順 11、 1の画像 1
    • Disconnect the cable from the right side of the modem.
  12. PowerBook G3 Lombard RAM Replacement: 手順 12、 1の画像 1
  13. PowerBook G3 Lombard RAM Replacement, Processor: 手順 13、 1の画像 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
  14. PowerBook G3 Lombard RAM Replacement: 手順 14、 1の画像 1
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
  15. PowerBook G3 Lombard RAM Replacement: 手順 15、 1の画像 1
  16. PowerBook G3 Lombard RAM Replacement, RAM: 手順 16、 1の画像 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • There are RAM slots on both sides of the processor. We recommend installing higher capacity chips on the bottom so that if you want to upgrade later, you won't have to remove the processor.
終わりに
6 の人々がこのガイドを完成させました。
添付文書
作成者
3人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 8,650
