はじめに
In order to access the display or replace any portion of the sound system you must first remove the speaker panel from the computer.
必要な工具と部品
Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
