メインコンテンツにスキップ
PowerBook 3400 M3553 Speaker Panel Replacement
必要な工具と部品
  1. PowerBook 3400 M3553 Speaker Panel Replacement, Battery: 手順 1、 1の画像 1
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
  2. PowerBook 3400 M3553 Speaker Panel Replacement: 手順 2、 2の画像 1 PowerBook 3400 M3553 Speaker Panel Replacement: 手順 2、 2の画像 2
    • Hold the button on the front left side and slide the battery out.
  3. PowerBook 3400 M3553 Speaker Panel Replacement, Keyboard: 手順 3、 1の画像 1
    • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
  4. PowerBook 3400 M3553 Speaker Panel Replacement: 手順 4、 3の画像 1 PowerBook 3400 M3553 Speaker Panel Replacement: 手順 4、 3の画像 2 PowerBook 3400 M3553 Speaker Panel Replacement: 手順 4、 3の画像 3
    • Turn the computer over and open the display. You should see that the keyboard is loose.
    • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
    • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
    • Carefully lift the top half of the keyboard and pull it towards yourself.
  5. PowerBook 3400 M3553 Speaker Panel Replacement: 手順 5、 2の画像 1 PowerBook 3400 M3553 Speaker Panel Replacement: 手順 5、 2の画像 2
    • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
    • Gently remove the ribbons from its tabs.
  6. PowerBook 3400 M3553 Speaker Panel Replacement, RAM: 手順 6、 2の画像 1 PowerBook 3400 M3553 Speaker Panel Replacement, RAM: 手順 6、 2の画像 2
    • Gently wiggle the RAM card to loosen the connection until it pulls free.
  7. PowerBook 3400 M3553 Speaker Panel Replacement, Speaker Panel: 手順 7、 2の画像 1 PowerBook 3400 M3553 Speaker Panel Replacement, Speaker Panel: 手順 7、 2の画像 2
    • Disconnect the wires from the port.
  8. PowerBook 3400 M3553 Speaker Panel Replacement: 手順 8、 1の画像 1
    • Remove the 7mm screw connecting the speaker panel to the computer.
  9. PowerBook 3400 M3553 Speaker Panel Replacement: 手順 9、 2の画像 1 PowerBook 3400 M3553 Speaker Panel Replacement: 手順 9、 2の画像 2
    • To detach the speaker panel's ribbon cable, use a plastic opening tool to lift the tabs on both sides of the cable port.
    • Once loose, pull the ribbon cable free.
  10. PowerBook 3400 M3553 Speaker Panel Replacement: 手順 10、 2の画像 1 PowerBook 3400 M3553 Speaker Panel Replacement: 手順 10、 2の画像 2
    • Lift the lighting/audio panel from it's bottom corners and pull the panel towards yourself.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Michael Mondragon
メンバー登録日: 04/12/11
274 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team 24-59, Amido Spring 2011 Cal Poly, Team 24-59, Amido Spring 2011人のメンバー
CPSU-AMIDO-S11S24G59
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 1,748
