この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If your keyboard is malfunctioning you can remove the keyboard to clean it. If that doesn't solve your problem you will need to replace the keyboard.
必要な工具と部品
Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
With a T8 torx screwdriver, remove the three 24mm torx screws along the middle of the back panel.
2 の人々がこのガイドを完成させました。
