メインコンテンツにスキップ
PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement
必要な工具と部品
  1. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery Side: 手順 1、 2の画像 1 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery Side: 手順 1、 2の画像 2
    • Battery is located in the right side headphone housing.
  2. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Heat Battery Housing: 手順 2、 1の画像 1
    • Use a heat gun with temperature set to 140 F for about 2-3 minutes and heat the casing where it attaches together as seen in the picture.
  3. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: 手順 3、 3の画像 1 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: 手順 3、 3の画像 2 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: 手順 3、 3の画像 3
    • After heating for about 2-3 minutes, separate the housing using a pry tool as seen in the pictures.
  4. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove/Replace Battery: 手順 4、 1の画像 1
    • Use a soldering iron to desolder battery connection to remove battery and replace with new one.
終わりに
13 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Faizan Naveed
メンバー登録日: 04/12/17
3,381 ポイント
8のガイドは作成済み
チーム
Mobile Device Repair Factory Mobile Device Repair Factory人のメンバー
Business
1 メンバー
16のガイドは作成済み
5 件のコメント
If you need this part you can order it here
https://www.joesge.com/products/powerbea...
JoesGE - 返信
My battery only was connected by two wires. Is that a newer edition of the Powerbeats than this one? Has Apple changed their wiring?
Andrew Manwaring - 返信
Where can I get the batteries? Is it available besides beats showroom?
Tara Chandrabura - 返信
My bettry is too good work but tha wireis want to b change
Asoo Malik - 返信
Plzz tel me how I can change tha wire of my power beats
Asoo Malik - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 81
今までの合計 29,667
