メインコンテンツにスキップ
PowerA Fusion Controller For Xbox One Buttons Replacement
必要な工具と部品
  1. PowerA Fusion Controller For Xbox One Buttons Replacement, Buttons: 手順 1、 3の画像 1 PowerA Fusion Controller For Xbox One Buttons Replacement, Buttons: 手順 1、 3の画像 2 PowerA Fusion Controller For Xbox One Buttons Replacement, Buttons: 手順 1、 3の画像 3
    • Remove the (9) nine 9.2mm screws with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
  2. PowerA Fusion Controller For Xbox One Buttons Replacement: 手順 2、 2の画像 1 PowerA Fusion Controller For Xbox One Buttons Replacement: 手順 2、 2の画像 2
    • Remove the (2) two 9.2mm screws with a JIS #1 screwdriver.
    • Remove the back cover of the controller.
    Would have been a better guide if you actually used a power a fusion controller.
    This is just a normal power a controller.
    Fusion has detachable cable and 4 detachable paddles on the back.
    Lol
    Qyuubix - 返信
  3. PowerA Fusion Controller For Xbox One Buttons Replacement: 手順 3、 3の画像 1 PowerA Fusion Controller For Xbox One Buttons Replacement: 手順 3、 3の画像 2 PowerA Fusion Controller For Xbox One Buttons Replacement: 手順 3、 3の画像 3
    • Remove the (5) five 9.2mm screws with a JIS #1 screwdriver.
    • Lift the motherboard and let it hang.
  4. PowerA Fusion Controller For Xbox One Buttons Replacement: 手順 4、 2の画像 1 PowerA Fusion Controller For Xbox One Buttons Replacement: 手順 4、 2の画像 2
    • Remove the (4) four 9.2mm screws that are holding the motherboard to the controller.
    • Put the motherboard aside.
  5. PowerA Fusion Controller For Xbox One Buttons Replacement: 手順 5、 2の画像 1 PowerA Fusion Controller For Xbox One Buttons Replacement: 手順 5、 2の画像 2
    • Remove the buttons.
  6. PowerA Fusion Controller For Xbox One Buttons Replacement: 手順 6、 2の画像 1 PowerA Fusion Controller For Xbox One Buttons Replacement: 手順 6、 2の画像 2
    • Go back to the motherboard, and remove the buttons' gasket with a tweezler.
    What do you do after you remove the button gasket
    AcridAssassin - 返信
    Do the buttons come with the gasket? Also the buttons are for an Xbox One controller. Does that mean they are compatible?
    Alexi Macias - 返信
終わりに
8 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Andrea
メンバー登録日: 09/26/17
623 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team S14-G4, Boczar Fall 2017 USF Tampa, Team S14-G4, Boczar Fall 2017人のメンバー
USFT-BOCZAR-F17S14G4
4 メンバー
5のガイドは作成済み
2 件のコメント
Okay so what do you do if by any chance one of the links that are sawdered to the mother board for the D Pad Connection cable breaks… Then what? How would I go about fixing that????
Heather Jesse - 返信
is there a guide to clean the bumpers out? my RB became less consistent and i'm hoping it's just because they're gunked up
urmum - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 91
今までの合計 18,406
