メインコンテンツにスキップ
PowerA Fusion Controller For Xbox One Analog Stick Replacement
必要な工具と部品
  1. PowerA Fusion Controller For Xbox One Analog Stick Replacement, Analog Stick: 手順 1、 3の画像 1 PowerA Fusion Controller For Xbox One Analog Stick Replacement, Analog Stick: 手順 1、 3の画像 2 PowerA Fusion Controller For Xbox One Analog Stick Replacement, Analog Stick: 手順 1、 3の画像 3
    • Remove the (9) nine 9.2mm screws with a JIS #1 screwdriver.
    • Lift off the two bottom grip covers of the controller.
  2. PowerA Fusion Controller For Xbox One Analog Stick Replacement: 手順 2、 2の画像 1 PowerA Fusion Controller For Xbox One Analog Stick Replacement: 手順 2、 2の画像 2
    • Remove the remaining (2) two 9.2mm screws holding the back cover with a JIS #1 screwdriver.
    • Carefully lift and remove the back cover of the controller.
  3. PowerA Fusion Controller For Xbox One Analog Stick Replacement: 手順 3、 3の画像 1 PowerA Fusion Controller For Xbox One Analog Stick Replacement: 手順 3、 3の画像 2 PowerA Fusion Controller For Xbox One Analog Stick Replacement: 手順 3、 3の画像 3
    • Carefully remove the (5) five 9.2mm screws holding the motherboard with a JIS #1 screwdriver.
    • Lift the motherboard and rest it face up to the right of the controller front plate.
  4. PowerA Fusion Controller For Xbox One Analog Stick Replacement: 手順 4、 2の画像 1 PowerA Fusion Controller For Xbox One Analog Stick Replacement: 手順 4、 2の画像 2
    • Remove the (4) four 9.2mm screws that are holding the motherboard to the controller.
    • Remove the motherboard from the face plate of the controller.
  5. PowerA Fusion Controller For Xbox One Analog Stick Replacement: 手順 5、 2の画像 1 PowerA Fusion Controller For Xbox One Analog Stick Replacement: 手順 5、 2の画像 2
    • Use the tweezers to unclip the (4) four metal teeth of the analog stick.
    • Use the soldering iron and desoldering braid to desolder the analog stick sensor module from the back of the motherboard.
    • Place the new analog stick sensor module and solder it back.
    • Use the はんだ付けとはんだ除去の作業ガイド guide on iFixit to help in desoldering and soldering the analog stick sensor module.
終わりに
7 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Marjan Mehedi
メンバー登録日: 09/27/17
173 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S14-G4, Boczar Fall 2017 USF Tampa, Team S14-G4, Boczar Fall 2017人のメンバー
USFT-BOCZAR-F17S14G4
4 メンバー
5のガイドは作成済み
3 件のコメント
Hi I’m looking those analog stick but I’m only finding the plastic and they are to big they are called different or something ?
Jose nobkes - 返信
Have you found a replacement yet? I ran into the same problem a couple of months ago, the potenciometers that I ordered did not fit into the motherboard. I even tried some other ones from a generic USB controler to no avail. Manufacturers do not report the sizes of the potenciometers, so it’s a bet everytime. I yet have to find a potentiometer that fits…
Franco Valdés -
Any joy on purchasing these
Mike Jones -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 67
今までの合計 15,030
