メインコンテンツにスキップ
PowerA Enhanced Wireless Controller L and R buttons Replacement
必要な工具と部品
  1. PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: 手順 1、 3の画像 1 PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: 手順 1、 3の画像 2 PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: 手順 1、 3の画像 3
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller L and R buttons Replacement: 手順 2、 1の画像 1
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller L and R buttons Replacement: 手順 3、 2の画像 1 PowerA Enhanced Wireless Controller L and R buttons Replacement: 手順 3、 2の画像 2
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller L and R buttons Replacement: 手順 4、 3の画像 1 PowerA Enhanced Wireless Controller L and R buttons Replacement: 手順 4、 3の画像 2 PowerA Enhanced Wireless Controller L and R buttons Replacement: 手順 4、 3の画像 3
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: 手順 5、 3の画像 1 PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: 手順 5、 3の画像 2 PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: 手順 5、 3の画像 3
    • Lift the two white latches using the iFixit opening tool.
    • Lift the white covering off.
  6. PowerA Enhanced Wireless Controller L and R buttons Replacement: 手順 6、 3の画像 1 PowerA Enhanced Wireless Controller L and R buttons Replacement: 手順 6、 3の画像 2 PowerA Enhanced Wireless Controller L and R buttons Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    購入する
    • Squeeze the buttons with rubber tweezers and push them in.
    • Grab it from the back and pull it out.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Ayjah Montgomery
メンバー登録日: 10/10/19
402 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team S1-G5, Leahy Fall 2019 USF Tampa, Team S1-G5, Leahy Fall 2019人のメンバー
USFT-LEAHY-F19S1G5
3 メンバー
10のガイドは作成済み
2 件のコメント
I need to know how to fix the ZR and the ZL buttons, like a faster response time
Starry Milligan - 返信
im sure this would be really helpful if i knew where i could buy the parts?
arch1e b - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 54
今までの合計 3,143
