はじめに
This guide will show you how to access and replace the L and R thumbsticks of your PowerA Enhanced Wireless Controller. If your buttons are sticking or result in drift, this is why you might need to replace or clean your thumbsticks.
Before starting, make sure to clean the controller of debris so the replacement is easier. Usually, thumbsticks can become worn out over multiple times of use, so replacing them can help with better gameplay. The pieces of this replacement can be fairly small, so having a steady hand and organization will be useful. This repair may seem unneeded because you can buy a new controller instead. Just doing this replacement can save you money and time. New parts may be required for this so make sure to buy your correct replacement parts in advance on either the Xbox website or your local gaming store.
必要な工具と部品
Remove the battery cover by pressing down on the lever located on the top of the cover.
Apply pressure until it clicks out of place, and pull it off.
11 の人々がこのガイドを完成させました。
19 件のコメント
i dont know i cleaned using plush sticks ( that usually go to ears that one ) i used that and isopropacol alcohoc 90%
it works for 2 weeks ( on me ) and now my Right analog stick is too Loose to wiggle there
BrunoS -
Where can I get replacement thumbsticks for this controller? Are they the same as the Switch Pro Controllers?
i need replacement joy-sticks too
BrunoS -
I need a link for the thumbsticks too. Cant seem to find them anywhere and PowerA does no sell them nor is willing to help.
