はじめに
This guide will show you how to access and replace the directional pad of your PowerA Enhanced Wireless Controller. Built-up residue can cause complications with the directional pad. As this cannot always be cleaned away with a Q-tip and rubbing alcohol, it may be necessary to disassemble the controller to either clean beneath the directional pad or change it entirely. Follow the steps provided to do so.
必要な工具と部品
Remove the battery cover by pressing down on the lever located on the top of the cover.
Apply pressure until it clicks out of place, and pull it off.
Use the rubber tweezers to grab the center of the directional pad and pull it out by pinching its center.
