メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
  1. Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  3. Remove the single Phillips #1 screw circled in the picture. Set it aside for later. The graphics card is outlined in red in the second image, if you are confused on where this is.
    • Remove the single Phillips #1 screw circled in the picture. Set it aside for later.
    • The graphics card is outlined in red in the second image, if you are confused on where this is.
  4. Lift the graphics card straight out of it's PCI slot.
    • Lift the graphics card straight out of it's PCI slot.
    • Be careful not to lift sideways, you can damage the PCI slot! Try your best to lift the graphics card straight up.
終わりに
ある他の人がこのガイドを完成しました。
Aaron Cooke
メンバー登録日: 2018年08月28日
21,054 ポイント
21のガイドは作成済み
チーム
NIWOTech NIWOTech人のメンバー
Community
0 メンバー
0のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 16
今までの合計 431
