はじめに
Review what the backup battery looks like, where it is, and how to replace it.
Your (actually my) PowerMac G5
the first picture is the front, the second is the side
please unplug before continuing, I don't want your electocuted
while the lever is up, grip the sides of the panel and pull
remove panel, you have to pull up first, then pull toward you
pull the plastic guard toward you, and remove using the same method as before
What you are left with, if your G5 panel says G5 twice, that is ok, it only means that you have two prossessors
the battery is a 3 volt cr2032 made by panasonic, replace with a similar battery to yours. it faces + down on my model, but it might not on yours, so you need to check before removing
to get the battery out, put your thumb under the battery, and push up while pulling the battery away from the motherboard (couldn't get a good picture of this)
to reassemble you computer, follow these steps in reverse order
13 の人々がこのガイドを完成させました。
