メインコンテンツにスキップ
Power Mac G4 Quicksilver Central Processing Unit Replacement
必要な工具と部品
  1. Power Mac G4 Quicksilver Central Processing Unit Replacement, Opening the case: 手順 1、 1の画像 1
    • The handle to open your computer is located on top of the right side panel.
  2. Power Mac G4 Quicksilver Central Processing Unit Replacement: 手順 2、 2の画像 1 Power Mac G4 Quicksilver Central Processing Unit Replacement: 手順 2、 2の画像 2
    • Grab the circular handle and pull outward.
  3. Power Mac G4 Quicksilver Central Processing Unit Replacement: 手順 3、 1の画像 1
    • Your computer is now open and ready for repair.
  4. Power Mac G4 Quicksilver Central Processing Unit Replacement, Video Adapter: 手順 4、 1の画像 1
    • This is your Power Mac G4's video adapter.
  5. Power Mac G4 Quicksilver Central Processing Unit Replacement: 手順 5、 1の画像 1
    • Start by removing the screw holding the card to the chassis as shown.
  6. Power Mac G4 Quicksilver Central Processing Unit Replacement: 手順 6、 1の画像 1
    • Before lifting the card out, this small plastic tab needs to be pulled back there by releasing it entirely.
  7. Power Mac G4 Quicksilver Central Processing Unit Replacement: 手順 7、 2の画像 1 Power Mac G4 Quicksilver Central Processing Unit Replacement: 手順 7、 2の画像 2
    • With the tab and screw removed, lift the card straight out.
    • When putting the card back in, take care to apply even pressure across the top with your thumbs. This will avoid damaging the card.
  8. Power Mac G4 Quicksilver Central Processing Unit Replacement, Central Processing Unit: 手順 8、 1の画像 1
    • First you want to remove the fan. Remove the two screws on the back of the computer in the upper left hand corner.
  9. Power Mac G4 Quicksilver Central Processing Unit Replacement: 手順 9、 2の画像 1 Power Mac G4 Quicksilver Central Processing Unit Replacement: 手順 9、 2の画像 2
    • Remove the fan unit by pulling straight up and out.
    • Be carful not to rip out the cord still attached to the motherboard. Remove it gently.
  10. Power Mac G4 Quicksilver Central Processing Unit Replacement: 手順 10、 2の画像 1 Power Mac G4 Quicksilver Central Processing Unit Replacement: 手順 10、 2の画像 2
    • You need detach the heat sink from the CPU. Locate the four clamps holding it down, two on each side.
    • Taking off the clamps can be difficult. Use a screwdriver to push down on the top of the clip. Then insert a spudger below the heat sink to pull it away from the board, releasing the heat sink.
  11. Power Mac G4 Quicksilver Central Processing Unit Replacement: 手順 11、 2の画像 1 Power Mac G4 Quicksilver Central Processing Unit Replacement: 手順 11、 2の画像 2
    • Pull the heat sink up and off of the CPU.
  12. Power Mac G4 Quicksilver Central Processing Unit Replacement: 手順 12、 1の画像 1
    • Remove the four screws holding the CPU to the motherboard.
  13. Power Mac G4 Quicksilver Central Processing Unit Replacement: 手順 13、 2の画像 1 Power Mac G4 Quicksilver Central Processing Unit Replacement: 手順 13、 2の画像 2
    • Now you can remove the CPU by pulling it straight up from the motherboard.
    • Be very careful when you detach the CPU. There is a connector that has hundreds of little prongs. You must not bend or break any of them! Be extremely careful.
  14. Power Mac G4 Quicksilver Central Processing Unit Replacement: 手順 14、 1の画像 1
    • You can now replace the CPU.
終わりに
11 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ryan Bylard
メンバー登録日: 01/20/10
1,325 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 14-41, Regan Winter 2010 Cal Poly, Team 14-41, Regan Winter 2010人のメンバー
CPSU-REGAN-W10S14G41
4 メンバー
17のガイドは作成済み
コメント 1 件
Removing graphics (video) card is not necessary. Also, removing the clips which retain heat-sink can be accomplished by using a flat-blade (-) screwdriver to carefully pry them from the finned aluminum assembly. Other than these two suggestions, guide is succinct and accurate.
analogcd - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 30
今までの合計 11,668
