メインコンテンツにスキップ
Power Mac G4 M5183 Internal Battery Replacement
  1. Power Mac G4 M5183 Internal Battery Replacement, Opening PowerMac G4 M5183 Case: 手順 1、 2の画像 1 Power Mac G4 M5183 Internal Battery Replacement, Opening PowerMac G4 M5183 Case: 手順 1、 2の画像 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
    Fino a li lo intuisce anche un bambino. Io volevo sapere come levare l'altro sportello senza rompere niente. Ma una vodtra risposta non la vedo.
    giorgus - 返信
  2. Power Mac G4 M5183 Internal Battery Replacement, Internal Battery: 手順 2、 2の画像 1 Power Mac G4 M5183 Internal Battery Replacement, Internal Battery: 手順 2、 2の画像 2
    • Locate the battery.
    • Remove and replace battery.
    • Push the PMU button once, and only once, to reset the power supply.
ゴール
21 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Justin Petrilli
メンバー登録日: 01/21/10
3,114 ポイント
11のガイドは作成済み
チーム
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S13G24
4 メンバー
25のガイドは作成済み
4 件のコメント
Nice simple post. You might make the battery number / size more obvious, for anxious nerds like me…
Thank you!
Lars-Peter Jorgensen - 返信
Not bad, but PMU button location is not explained… the button on the front to start it?
rwwseditor - 返信
Hi
Will a 3V Lithium battery work or must it be 3.6V?
Please advise.
Rgds
Duard
Duard Kleyn - 返信
The PMU reset button is inside the casing, on the same circuit board as the backup battery holder. See the second photo, it's a small silver square with a circular black button inset into its top and PMU Reset in tiny white lettering beside it. The photo shows it near to the battery holder but on my model the button is further away on the far corner of the circuit board. Look around for it. Insert the new battery then press the reset ONE time only.
Robert Nicholson - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 97
今までの合計 25,185
