メインコンテンツにスキップ
Power Mac G4 Cube Modem Replacement
必要な工具と部品
  1. Power Mac G4 Cube Modem Replacement, Outer Case: 手順 1、 3の画像 1 Power Mac G4 Cube Modem Replacement, Outer Case: 手順 1、 3の画像 2 Power Mac G4 Cube Modem Replacement, Outer Case: 手順 1、 3の画像 3
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube Modem Replacement: 手順 2、 2の画像 1 Power Mac G4 Cube Modem Replacement: 手順 2、 2の画像 2
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
  3. Power Mac G4 Cube Modem Replacement: 手順 3、 1の画像 1
    • Slowly lift the plate off the cube and disconnect the power cord.
  4. Power Mac G4 Cube Modem Replacement: 手順 4、 1の画像 1
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
  5. Power Mac G4 Cube Modem Replacement, Video Card: 手順 5、 1の画像 1
    • Remove the screws on the back of the VGA port.
  6. Power Mac G4 Cube Modem Replacement: 手順 6、 1の画像 1
    • Remove the screw attaching the video card to the logic board.
  7. Power Mac G4 Cube Modem Replacement: 手順 7、 2の画像 1 Power Mac G4 Cube Modem Replacement: 手順 7、 2の画像 2
    • Remove power cord from the video card.
  8. Power Mac G4 Cube Modem Replacement: 手順 8、 1の画像 1
    • Remove the power cord.
    • Remove the connector.
    • Remove the video card from the logic board.
  9. Power Mac G4 Cube Modem Replacement: 手順 9、 1の画像 1
    • Carefully lift the video card from the logic board.
    • The video card should come out easily.
  10. Power Mac G4 Cube Modem Replacement: 手順 10、 2の画像 1 Power Mac G4 Cube Modem Replacement: 手順 10、 2の画像 2
    • Separate the video card from the adapter.
  11. Power Mac G4 Cube Modem Replacement, Modem: 手順 11、 1の画像 1
    • Remove the two screws from the modem.
  12. Power Mac G4 Cube Modem Replacement: 手順 12、 1の画像 1
    • Lift modem from the Logic Board.
    • The modem should come out easily.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Ryan Chun
メンバー登録日: 06/24/10
1,076 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 2-7, Johann Summer 2010 Cal Poly, Team 2-7, Johann Summer 2010人のメンバー
CPSU-JOHANN-R10S2G7
5 メンバー
21のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 34
今までの合計 4,445
