この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Installing the Airport Card involves removing the outer case before actual installation.
必要な工具と部品
Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
Push back the handle after you have taken the core out of the case.
Pull outwards on the antenna cable.
Pull on the clear tab outwards to remove the existing AirPort card
Slide in the new AirPort card and connect the antenna cable
8 の人々がこのガイドを完成させました。
