はじめに
Installing the Airport Card involves removing the outer case.
Release the handle at the bottom of the Power Mac G4 Cube by pushing it down. Slowly pull out the cube by holding the end of the handle.
Push back the handle after you have taken the core out of the case.
Pull outwards on the antenna cable.
Pull on the clear tab outwards to remove the existing AirPort card
Slide in the new AirPort card.
Reconnect the antenna cable.
8 の人々がこのガイドを完成させました。
