メインコンテンツにスキップ
Porter-Cable PC60TAG Motor Assembly Replacement
必要な工具と部品
  1. Porter-Cable PC60TAG Motor Assembly Replacement, Motor Assembly: 手順 1、 1の画像 1
    • Using the Phillips #2 screwdriver, remove the 3/4" Phillips screw on the back cover.
  2. Porter-Cable PC60TAG Motor Assembly Replacement: 手順 2、 1の画像 1
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Motor Assembly Replacement: 手順 3、 1の画像 1
    • Using the Phillips #2 screwdriver, remove the1/2" Phillips screw holding on the motor brush arm. Repeat on the other side.
  4. Porter-Cable PC60TAG Motor Assembly Replacement: 手順 4、 1の画像 1
    • Carefully pull the motor brush arm away from the other device, you can leave the wire connected to device. Repeat on the other side.
  5. Porter-Cable PC60TAG Motor Assembly Replacement: 手順 5、 1の画像 1
    • Using the Phillips #2 screwdriver, remove the 1 inch black retainer screw.
  6. Porter-Cable PC60TAG Motor Assembly Replacement: 手順 6、 1の画像 1
    • Using the Phillips #2screwdriver, remove the 4, 1/2" Phillips screws around the head gear.
  7. Porter-Cable PC60TAG Motor Assembly Replacement: 手順 7、 1の画像 1
    • Carefully pull the head gear away from the device, and set aside.
  8. Porter-Cable PC60TAG Motor Assembly Replacement: 手順 8、 1の画像 1
    • Using the Phillips #2 screwdriver, remove the two, 1/2" screws holding the head to the body on the bottom side of the grinder.
  9. Porter-Cable PC60TAG Motor Assembly Replacement: 手順 9、 1の画像 1
    • Using the Phillips #2 screwdriver, remove the other two 1/2" screws holding the head to the body on the top side of the grinder.
  10. Porter-Cable PC60TAG Motor Assembly Replacement: 手順 10、 1の画像 1
    • Holding the head of the device, carefully pull the motor assembly out of the body of the device.
  11. Porter-Cable PC60TAG Motor Assembly Replacement: 手順 11、 1の画像 1
    • Using a 9/16" wrench, loosen the spindle nut inside the head, from the motor assembly.
  12. Porter-Cable PC60TAG Motor Assembly Replacement: 手順 12、 1の画像 1
    • Pull the motor assembly away from the head.
終わりに
作成者
2人の作成者と共同で作成されました。
Mackenzie Fairbanks
メンバー登録日: 03/24/16
591 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 2-2, Isaacson Spring 2016 UMass Dartmouth, Team 2-2, Isaacson Spring 2016人のメンバー
UMASSD-ISAACSON-S16S2G2
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 524
