メインコンテンツにスキップ
Porter-Cable 382 Dust Seal | Dust Break Replacement
必要な工具と部品
  1. Porter-Cable 382 Dust Seal | Dust Break Replacement, Sander Pad: 手順 1、 1の画像 1
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Dust Seal | Dust Break Replacement: 手順 2、 1の画像 1
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
  3. Porter-Cable 382 Dust Seal | Dust Break Replacement, Dust Seal/ Break: 手順 3、 1の画像 1
    • Once the sander pad is removed and the sander is exposed locate the white plastic like circular piece surrounding the outside of the sander.
  4. Porter-Cable 382 Dust Seal | Dust Break Replacement: 手順 4、 2の画像 1 Porter-Cable 382 Dust Seal | Dust Break Replacement: 手順 4、 2の画像 2
    • Once you have located the plastic white ring pull up its outer edge as shown. The lip on the inside will bend and be freed from its secured placement.
    • To reassemble, you will have to line up the protruding square with the key slot as shown otherwise your dust seal/ brake will not go back in.
終わりに
作成者
2人の作成者と共同で作成されました。
jpfoxracing9
メンバー登録日: 03/11/16
189 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 8-7, Botvin Spring 2016 UMass Dartmouth, Team 8-7, Botvin Spring 2016人のメンバー
UMASSD-BOTVIN-S16S8G7
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 12
今までの合計 548
