メインコンテンツにスキップ
Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement
必要な工具と部品
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement, Removing the Battery Cover: 手順 1、 3の画像 1 Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement, Removing the Battery Cover: 手順 1、 3の画像 2 Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement, Removing the Battery Cover: 手順 1、 3の画像 3
    • Hold the mouthpiece of the handset and locate the lock-unlock text.
    • Twist the battery cover counterclockwise from the "lock" to the "unlock" position.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement, Disconnecting the Battery Wire: 手順 2、 3の画像 1 Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement, Disconnecting the Battery Wire: 手順 2、 3の画像 2 Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement, Disconnecting the Battery Wire: 手順 2、 3の画像 3
    • To disconnect the battery pack wire from the phone, squeeze the tab against the connector and pull connector straight up from the socket.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement, Removing the Battery Pack: 手順 3、 3の画像 1 Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement, Removing the Battery Pack: 手順 3、 3の画像 2 Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement, Removing the Battery Pack: 手順 3、 3の画像 3
    • Pull the battery from the battery compartment.
    • You may need to gently wiggle the battery back and forth in its compartment to help loosen it.
  4. Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement, Removing Microphone Cover Screw: 手順 4、 1の画像 1
    • Use a Philips #00 screwdriver to remove the single 7mm screw.
  5. Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement, Prying off the Microphone Cover: 手順 5、 3の画像 1 Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement, Prying off the Microphone Cover: 手順 5、 3の画像 2 Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement, Prying off the Microphone Cover: 手順 5、 3の画像 3
    • Use the spudger to begin prying the microphone cover off of the handset piece.
    • As you pry up the cover, slide the spudger around the gap to separate the two pieces.
    • Use the opening tools to wedge into the larger gaps and further pry apart the pieces.
    • Prying apart the two pieces is difficult and will take effort. It helps if you wedge multiple tools on different sides of the gap. There is no need to be gentle.
  6. Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement, Uncovering Wire Connections: 手順 6、 3の画像 1 Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement, Uncovering Wire Connections: 手順 6、 3の画像 2 Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement, Uncovering Wire Connections: 手順 6、 3の画像 3
    • Use the spudger to scrape the glue away from the wire connections.
    • Use the spudger to scrape and tweezers to pull away the black foam covering the other wire connections.
  7. Polyconcept 900-MHz Retro Cordless Telephone Device Microphone Replacement, Desoldering Wire Connections: 手順 7、 1の画像 1
    • Use the soldering station to desolder the wire connections.
    • For further instructions on using the soldering station click here.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Tia
メンバー登録日: 10/27/14
472 ポイント
3のガイドは作成済み
チーム
Eastern Washington University, Team 1-1, Carnegie Fall 2014 Eastern Washington University, Team 1-1, Carnegie Fall 2014人のメンバー
EWU-CARNEGIE-F14S1G1
6 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 207
