はじめに
Prerequisite Only
パーツ
パーツは必要ありません。
  1. To disconnect the phone cord, squeeze the tab against the connector and pull the cord away from the telephone-line-in-jack. To disconnect the power cord, grasp the end and pull back and away until it is disconnected. Once disconnected remove each cord from its track.
    • To disconnect the phone cord, squeeze the tab against the connector and pull the cord away from the telephone-line-in-jack.
    • To disconnect the power cord, grasp the end and pull back and away until it is disconnected.
    • Once disconnected remove each cord from its track.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. Using a Phillips #00 screwdriver, remove the six 7mm screws from the base plate.
    • Using a Phillips #00 screwdriver, remove the six 7mm screws from the base plate.
  4. With the base turned upside down, grasp the edges of the base plate and  gently lift from the rest of the base. Two wires lead from the motherboard to the charger plate, so the two parts cannot be completely separated without further steps. Two wires lead from the motherboard to the charger plate, so the two parts cannot be completely separated without further steps.
    • With the base turned upside down, grasp the edges of the base plate and gently lift from the rest of the base.
    • Two wires lead from the motherboard to the charger plate, so the two parts cannot be completely separated without further steps.
まとめ
ある他の人がこのガイドを完成しました。
Jay Gunter
メンバー登録日: 2014年10月27日
372 ポイント
3のガイドは作成済み
チーム
Eastern Washington University, Team 1-1, Carnegie Fall 2014 Eastern Washington University, Team 1-1, Carnegie Fall 2014人のメンバー
EWU-CARNEGIE-F14S1G1
6 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 236
