メインコンテンツにスキップ
Polk MagniFi Soundbar Motherboard Replacement
必要な工具と部品
  1. Polk MagniFi Soundbar Motherboard Replacement, The Motherboard: 手順 1、 1の画像 1
    • To begin, remove the 8 screws locating on the back of the soundbar. These can be removed with the ifixit screwdriver equipped with a Phillips'head in size J1.
    • The cover will lift up, but there will be wires underneath connected to the cover that need to be unscrewed.
    • The 8 screws on the back cover, as well as the screws removed in the following steps, are all the exact same length (approx. 1 centimeter). Keep track of all screws but do not worry if they become mixed up.
  2. Polk MagniFi Soundbar Motherboard Replacement: 手順 2、 2の画像 1 Polk MagniFi Soundbar Motherboard Replacement: 手順 2、 2の画像 2
    • Remove the two screws using the Phillips #1 screwdriver. Once they are unscrewed, the panels will hang loose allowing unobstructed access to the motherboard.
  3. Polk MagniFi Soundbar Motherboard Replacement: 手順 3、 3の画像 1 Polk MagniFi Soundbar Motherboard Replacement: 手順 3、 3の画像 2 Polk MagniFi Soundbar Motherboard Replacement: 手順 3、 3の画像 3
    • Remove the three sets of wires plugged into the motherboard (image 1). These are removed by gripping the base of the wire firmly and pulling straight up.
    • Unscrew and remove the four screws (two on either side) to release the motherboard from the rest of the soundbar (Images 2 & 3).
  4. Polk MagniFi Soundbar Motherboard Replacement: 手順 4、 2の画像 1 Polk MagniFi Soundbar Motherboard Replacement: 手順 4、 2の画像 2
    • Now that the soundbar is unscrewed, carefully lift the motherboard up and remove the wire attached to the underside of it. To do this firmly grasp the wires at the base (image 1) and pull them straight up.
    • The motherboard is now completely detached.
    • This component is fragile, and this step needs to be done carefully.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
[deleted]
メンバー登録日: 10/22/18
635 ポイント
4のガイドは作成済み
10 件のコメント
Where do you buy the motherboard?
luism60613 - 返信
Where do you buy the mother board?
klwalker1965 - 返信
Where do you buy a replacement motherboard? ???
Todd Guenther - 返信
Same question- where do you buy the replacement motherboard?
LL Poffo - 返信
I need a motherboard - where do I purchase it?
Tim - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 26
過去 30 日: 119
今までの合計 6,075
