この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If your soundbar is working but you are unable to control the power or volume with the buttons on top of the soundbar they may be stuck. Follow this guide to remove any dust.
必要な工具と部品
To reveal the control button, first, carefully remove the front cover of the Sound Bar.
Use the plastic iFixit opening tool to lift up the front surface. Insert the tool between the cover and the body to open it.
After the cover is fully removed, it will be able to see the interior speaker.
Remove all screws from the front surface. all screws are approximately 1.50 centimeters.
コメント 1 件
My pollk is working but there is no sound coming out it connect the Bluetooth and wifi but my problem is there is no sound coming
