はじめに
This is straight forward and should be easily accomplished. The toughest part on this repair is to remove the front case. It does bind a bit around the USB port, but will free with a bit of shimming.
パーツ
パーツは指定されていません。
  1. remove the batteries, the memory card as well as the carrying strip (if so equipped). Remove the 2 screws on the right hand side. Remove the 2 screws on the left hand side.
    • remove the batteries, the memory card as well as the carrying strip (if so equipped).
    • Remove the 2 screws on the right hand side.
    • Remove the 2 screws on the left hand side.
  2. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  3. One more screw on the bottom, underneath the manufacturer's label. Start spitting the case from the battery compartment. You can use a plastic opening tool, or your finger nails. It does bind a bit at the USB port side, but will separate pretty quick. With the back removed, the large LCD becomes immediately visible. There are no fasteners, it just rests inside the tray.
    • One more screw on the bottom, underneath the manufacturer's label.
    • Start spitting the case from the battery compartment. You can use a plastic opening tool, or your finger nails. It does bind a bit at the USB port side, but will separate pretty quick.
    • With the back removed, the large LCD becomes immediately visible. There are no fasteners, it just rests inside the tray.
  4. Lift the LCD out of the tray and move it to the right of the tray. The cable is still attached to the logic board via a latch. With the plastic opening tool, or your fingernails, gently flip the latch to the left side. This will free the LCD cable. Remove the LCD and install your new one.
    • Lift the LCD out of the tray and move it to the right of the tray. The cable is still attached to the logic board via a latch.
    • With the plastic opening tool, or your fingernails, gently flip the latch to the left side. This will free the LCD cable. Remove the LCD and install your new one.
まとめ
oldturkey03
メンバー登録日: 2010年09月29日
578,870 ポイント
101のガイドは作成済み
チーム
OTS OTS人のメンバー
Business
1 メンバー
127のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 934
