メインコンテンツにスキップ
Polaroid i533 Outer Case Replacement
必要な工具と部品
  1. Polaroid i533 Outer Case Replacement, Outer Case: 手順 1、 2の画像 1 Polaroid i533 Outer Case Replacement, Outer Case: 手順 1、 2の画像 2
    • Unscrew and remove the four screws from the left side of the camera (from the screen's view)
  2. Polaroid i533 Outer Case Replacement: 手順 2、 1の画像 1
    • Unscrew and remove the three screws from the bottom of the camera
  3. Polaroid i533 Outer Case Replacement: 手順 3、 2の画像 1 Polaroid i533 Outer Case Replacement: 手順 3、 2の画像 2
    • Unscrew and remove the two screws from the right side of the camera.
  4. Polaroid i533 Outer Case Replacement: 手順 4、 2の画像 1 Polaroid i533 Outer Case Replacement: 手順 4、 2の画像 2
    • Open the battery flap and remove the batteries.
    • Keep the battery flap open.
  5. Polaroid i533 Outer Case Replacement: 手順 5、 1の画像 1
    • Use a spudger to gently separate the two halves of the camera's outer casing.
  6. Polaroid i533 Outer Case Replacement: 手順 6、 1の画像 1
    • Gently pull the half of the case with the screen (the back half) from the rest of the camera.
    • Be sure not too pull to hard. The screen is still attached to the motherboard. If you pull too hard you will rip it.
  7. Polaroid i533 Outer Case Replacement: 手順 7、 2の画像 1 Polaroid i533 Outer Case Replacement: 手順 7、 2の画像 2
    • The back half (the half with the screen on it) should now be separate from the rest of the camera, but still attached by the ribbon.
  8. Polaroid i533 Outer Case Replacement: 手順 8、 2の画像 1 Polaroid i533 Outer Case Replacement: 手順 8、 2の画像 2
    • Use a spudger to lift the black flap that clamps the ribbon towards you.
    • When the black flap is open it will be straight up. (like in the second picture)
  9. Polaroid i533 Outer Case Replacement: 手順 9、 1の画像 1
    • Now that the black flap is open, gently pull the ribbon out.
    • You should now have the back half of the camera completely separate from the rest of the camera.
  10. Polaroid i533 Outer Case Replacement: 手順 10、 2の画像 1 Polaroid i533 Outer Case Replacement: 手順 10、 2の画像 2
    • This is what the back half of the camera should look like.
    • This is what the rest of the camera will look like.
  11. Polaroid i533 Outer Case Replacement: 手順 11、 1の画像 1
    • Unscrew and remove two screws from the logic board.
  12. Polaroid i533 Outer Case Replacement: 手順 12、 1の画像 1
    • Pull the front half off of the logic board.
  13. Polaroid i533 Outer Case Replacement: 手順 13、 1の画像 1
    • This will be the front half of the outer case.
終わりに
作成者
4人の作成者と共同で作成されました。
Terichael Office
メンバー登録日: 06/24/10
9 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 3-4, Johann Summer 2010 Cal Poly, Team 3-4, Johann Summer 2010人のメンバー
CPSU-JOHANN-R10S3G4
4 メンバー
9のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 1,466
