メインコンテンツにスキップ
Polaroid SNAP Flash Cover Replacement
必要な工具と部品
  1. Polaroid SNAP Flash Cover Replacement, Polaroid SNAP Front and Back Face Plate Removal: 手順 1、 1の画像 1
    • Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Screw head: Phillips, Screw length: 3mm
  2. Polaroid SNAP Flash Cover Replacement: 手順 2、 2の画像 1 Polaroid SNAP Flash Cover Replacement: 手順 2、 2の画像 2
    • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
    • Then it should be easy to simply lift the rear face plate up and remove it.
  3. Polaroid SNAP Flash Cover Replacement: 手順 3、 2の画像 1 Polaroid SNAP Flash Cover Replacement: 手順 3、 2の画像 2
    • Locate and remove the four screws on the corners of the camera, they're quite small and may be difficult to remove.
    • Screw head: Philips, Screw length: 5mm
  4. Polaroid SNAP Flash Cover Replacement: 手順 4、 3の画像 1 Polaroid SNAP Flash Cover Replacement: 手順 4、 3の画像 2 Polaroid SNAP Flash Cover Replacement: 手順 4、 3の画像 3
    • Once the screws are removed, flip the camera over
    • Use a plastic opening tool to disengage the six clips until the front face plate can be removed safely
  5. Polaroid SNAP Flash Cover Replacement: 手順 5、 1の画像 1
    • The cameras innards should now be accessible to you
  6. Polaroid SNAP Flash Cover Replacement, Flash Cover: 手順 6、 2の画像 1 Polaroid SNAP Flash Cover Replacement, Flash Cover: 手順 6、 2の画像 2
    • Flip the front face-plate over, so that you’re are looking at the silver plate on the inside.
  7. Polaroid SNAP Flash Cover Replacement: 手順 7、 1の画像 1
    • Use a plastic opening tool and pull up on the small metal tab in the middle-left inside of the front face-plate.
  8. Polaroid SNAP Flash Cover Replacement: 手順 8、 1の画像 1
    • While pulling up on the metal tab with the plastic opening tool, use your thumb to gently push the metal plate slightly to the right in order to release it from the tabs holding it to the face-plate.
  9. Polaroid SNAP Flash Cover Replacement: 手順 9、 1の画像 1
    • Once the metal plate is released from the tabs, carefully separate it from the face-plate by pulling it outwards.
  10. Polaroid SNAP Flash Cover Replacement: 手順 10、 1の画像 1
    • After the metal plate is removed from the front face-plate, locate the small clear flash cover on the top right of the faceplate. The flash cover should easily pop out of place.
  11. Polaroid SNAP Flash Cover Replacement: 手順 11、 1の画像 1
    • Remove the flash cover and place in the new one, with the holes of the flash cover oriented in the top right and bottom left corners.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Austin Broyles
メンバー登録日: 02/09/16
249 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 7-3, Cheng Spring 2016 USF Tampa, Team 7-3, Cheng Spring 2016人のメンバー
USFT-CHENG-S16S7G3
4 メンバー
19のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 23
今までの合計 2,075
