メインコンテンツにスキップ
Polaroid PTAB7XC Battery Replacement
必要な工具と部品
  1. Polaroid PTAB7XC Battery Replacement, Battery: 手順 1、 2の画像 1 Polaroid PTAB7XC Battery Replacement, Battery: 手順 1、 2の画像 2
    • Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver, turning them counterclockwise.
    • If the screw heads have corroded or been stripped, it may be necessary to use a larger screwdriver head, such as the J0.
  2. Polaroid PTAB7XC Battery Replacement: 手順 2、 3の画像 1 Polaroid PTAB7XC Battery Replacement: 手順 2、 3の画像 2 Polaroid PTAB7XC Battery Replacement: 手順 2、 3の画像 3
    • Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
    • Lift the device off of the case and flip over the device so that it sits screen side down.
    • The device is now free from the plastic casing.
    • The power and/or volume buttons may fall out at this point. There is no problem with this; however, be sure to remember to reinstall them when reassembling the device.
  3. Polaroid PTAB7XC Battery Replacement: 手順 3、 2の画像 1 Polaroid PTAB7XC Battery Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • Wedge a plastic card beneath the battery unit.
    • Wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
    • Do not rupture the battery; it poses a serious safety hazard.
    • There is a plastic bag around the battery; if torn or stretched, there is no safety hazard.
  4. Polaroid PTAB7XC Battery Replacement: 手順 4、 3の画像 1 Polaroid PTAB7XC Battery Replacement: 手順 4、 3の画像 2 Polaroid PTAB7XC Battery Replacement: 手順 4、 3の画像 3
    • Set the device on a heat safe surface.
    • Desolder from the motherboard the red wire that connects to the battery unit.
    • Desolder from the motherboard the black wire that connects to the battery unit.
    • Lift the battery out of the device using your hands.
    • The battery is now free from the device.
    • If either of the wires do not come completely free when desoldering, use tweezers to gently pull them free.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Meg Lybbert
メンバー登録日: 10/08/15
649 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team 2-2, Plummer Fall 2015 Eastern Washington University, Team 2-2, Plummer Fall 2015人のメンバー
EWU-PLUMMER-F15S2G2
4 メンバー
6のガイドは作成済み
コメント 1 件
This tablet has the exact same setup as the 2011-2012 nextbook part might be interchangeable with this tablet .
Walker wallace - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,070
