はじめに
Charging port is very important for every device. If you don't fix it on time, the device won't turn on anymore.
必要な工具と部品
Pry the seam between the screen and the case and slide it on all four sides with a large plastic opening tool until the plastic case comes off.
この手順で使用する道具:Plastic Cards$2.99
Wedge a plastic card beneath the battery unit and wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
Remove the two 5mm screws attached to the top right and bottom left corners of the speaker
Using the ph#00 screwdriver, remove the four 5mm screws connecting the motherboard to the casing.
この手順で使用する道具:Tweezers$4.99
Desolder each side of the USB port where it is attached to the motherboard.
The USB port will now be loosened from the motherboard.
Using tweezers, pull the USB port straight out from the motherboard without wiggling it up, down, or side to side.
The USB port is now replaceable.
