メインコンテンツにスキップ
Polaroid Onestep Close Up Close Up Lens Replacement
必要な工具と部品
  1. Polaroid Onestep Close Up Close Up Lens Replacement, Flash Assembly Removal: 手順 1、 3の画像 1 Polaroid Onestep Close Up Close Up Lens Replacement, Flash Assembly Removal: 手順 1、 3の画像 2 Polaroid Onestep Close Up Close Up Lens Replacement, Flash Assembly Removal: 手順 1、 3の画像 3
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Polaroid Onestep Close Up Close Up Lens Replacement, Opening Film Tray: 手順 2、 2の画像 1 Polaroid Onestep Close Up Close Up Lens Replacement, Opening Film Tray: 手順 2、 2の画像 2
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Close Up Lens Replacement, Removing Face Plate: 手順 3、 3の画像 1 Polaroid Onestep Close Up Close Up Lens Replacement, Removing Face Plate: 手順 3、 3の画像 2 Polaroid Onestep Close Up Close Up Lens Replacement, Removing Face Plate: 手順 3、 3の画像 3
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Close Up Lens Replacement, Removing the slider: 手順 4、 1の画像 1
    • Pry off the slider (the light gray piece) by slipping it out from beneath the tabs (their location is indicated by the two red circles).
  5. Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Face Plate: 手順 5、 3の画像 1 Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Face Plate: 手順 5、 3の画像 2 Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Face Plate: 手順 5、 3の画像 3
    この手順で使用する道具:
    • Pry off the face plate at the locations shown by using a rigid prying tool (either tweezers or the blue plastic opening tool). These spaces can be very tight.
    • You'll know if you were successful if you can fully remove the face plate.
  6. Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Spring: 手順 6、 2の画像 1 Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Spring: 手順 6、 2の画像 2
    • Use tweezers to lift the ring of the spring off of the hook it is attached to.
    • Gently loosen and remove the spring.
  7. Polaroid Onestep Close Up Close Up Lens Replacement, Removing the First Part of the Close Up Lens: 手順 7、 2の画像 1 Polaroid Onestep Close Up Close Up Lens Replacement, Removing the First Part of the Close Up Lens: 手順 7、 2の画像 2
    • Slide the CloseUp lens piece all the way to the left. It should separate without any resistance.
  8. Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Second Part of the Close Up Lens: 手順 8、 2の画像 1 Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Second Part of the Close Up Lens: 手順 8、 2の画像 2
    • Make sure the last plastic piece is set all the way to the right. Using the blue plastic tool, pry it loose. It should easily pop out.
終わりに
2 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Jordan
メンバー登録日: 09/22/14
471 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 3-5, Brown Fall 2014 USF Tampa, Team 3-5, Brown Fall 2014人のメンバー
USFT-BROWN-F14S3G5
3 メンバー
6のガイドは作成済み
2件のガイドコメント
Which model is the "precious" one?
Dan Brown - 返信
anyone know where i can buy the close up lens?
finbarlaverty - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 30
今までの合計 2,229
