メインコンテンツにスキップ
Polaroid Now i-Type Film Pack Replacement
必要な工具と部品
ビデオの概要
  1. Polaroid Now i-Type Film Pack Replacement, Open The Film Pack Door: 手順 1、 2の画像 1 Polaroid Now i-Type Film Pack Replacement, Open The Film Pack Door: 手順 1、 2の画像 2
    • Open the door using the eject button on the side of the Polaroid Now camera make sure to hold the camera in such a way as to not obstruct the film door hinge
  2. Polaroid Now i-Type Film Pack Replacement, (Optional)* Take Out Old Film: 手順 2、 2の画像 1 Polaroid Now i-Type Film Pack Replacement, (Optional)* Take Out Old Film: 手順 2、 2の画像 2
    • If there is an empty film pack in your camera take it out using the sides of the pack or the rainbow tab on the film.
    • If you know that there is still film in the pack note that the exposure/photo will be exposed and will not show a photo if you put said film pack back in the camera at a later time.
    • *Normally there is no film pack in the camera when you open the door so you may skip this step.
  3. Polaroid Now i-Type Film Pack Replacement, Insert New i-Type Film Pack: 手順 3、 2の画像 1 Polaroid Now i-Type Film Pack Replacement, Insert New i-Type Film Pack: 手順 3、 2の画像 2
    • The film pack comes in a silver-plastic wrapping, take this off by ripping it and throw away/recycle it.
    • Now, insert the film into the camera with the dark slide up and the rainbow tab facing towards you. Make sure to not squish the film as this may expose/ beak the chemical packet in the film.
    • Push pack in firmly until you hear a click.
    • Film Types Supported By Polaroid Now: - i-Type Color - i-Type B&W - Vintage Polaroid 600 Film - Modern Polaroid 600, Special Edition, B&W, Monochrome and, Circular - Polaroid SX-70 (FILM WILL BE UNDEREXPOSED AND BAD, FOR USE IN A PINCH)
    • Make Sure You Hear A Click
    • Push the film pack in and when you close the door make sure your hands are not in the way of the film eject slot, watch as the dark slide ejects, flick the frog younger up and take the Darkslide out. You are now ready to take pictures.
    • Refer to Step 3 for removing the pack once you are done.
ゴール
作成者
1人の作成者と共同作成されました。
Trstnnexus123
メンバー登録日: 01/21/23
121 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 45
今までの合計 359
