メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Polaroid LCD-0700P Metal Holding Bars Replacement
必要な工具と部品
    1. Polaroid LCD-0700P Metal Holding Bars Replacement, Case: 手順 1、 2の画像 1 Polaroid LCD-0700P Metal Holding Bars Replacement, Case: 手順 1、 2の画像 2
      • Turn the entire device over, so that the underside of the device is facing upward.
      • With the underside of the device facing up, locate the 11mm screw found in each far corner of the device. Remove the single 11mm screw from each of the four corners, using the Phillips #0 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    2. Polaroid LCD-0700P Metal Holding Bars Replacement: 手順 2、 2の画像 1 Polaroid LCD-0700P Metal Holding Bars Replacement: 手順 2、 2の画像 2
      • Turn the device so that the underside faces you, and the edge where the case and device bind, faces upward. The opening of the device should be face down.
      • In this position you will see a crease line between the device and the top cover. Gently Insert your blue plastic opening tool into the crack of the crease line, between the front and back cover to separate them.
      • Be careful when separating the front and back covers, as the two are held together by a thin wire.
      • Separate the halves of the case.
      FixBotに聞いてみる
      コメントを追加
    3. Polaroid LCD-0700P Metal Holding Bars Replacement: 手順 3、 1の画像 1
      • Locate the input/output board on the top left hand corner of the device. It will look like a green circuit board with wires protruding and connecting to the case cover.
      • Using your blue plastic opening tool, disconnect the multicolored wires located on the input/output board. These will be the same multicolored wires that connect the back cover to the input/output board.
      FixBotに聞いてみる
      コメントを追加
    1. Polaroid LCD-0700P Metal Holding Bars Replacement, Metal Holding Bars: 手順 4、 1の画像 1
      • Use a Philips #0 screwdriver to remove the screws for the bar you are replacing.
      FixBotに聞いてみる
      コメントを追加
    2. Polaroid LCD-0700P Metal Holding Bars Replacement: 手順 5、 1の画像 1
      • Slide out the bar.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Kevin
メンバー登録日: 01/20/12
22 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 8-14, Maness Winter 2012 Cal Poly, Team 8-14, Maness Winter 2012人のメンバー
CPSU-MANESS-W12S8G14
4 メンバー
32のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 35
今までの合計 1,167
