はじめに
Use this guide to replace, change, or upgrade the front shell (aka front cover) on your Polaroid Go (Gen 1 or 2) instant camera.
You may want to change the front shell if it's cracked or damaged, or if you want to customize your camera with different colors.
必要な工具と部品
If you have any film left, take some photos! Disassembly will expose any leftover film.
Before you begin, unplug all cables from your camera and fully power it down.
Set your camera down so the bottom is facing up.
Use the latch on the bottom of the camera to open the film door.
Use your fingers to lift and remove the film cartridge.
この手順で使用する道具:Flexible Extension$6.99
Use a Phillips screwdriver to remove the two 4.2 mm‑long front shell screws from the film compartment.
Secure the back of the camera with one hand, and use your free hand to gently pull the front shell away from the camera until a slight gap forms.
Close the film door, making sure the latch doesn't re‑engage.
Flip your camera over so the take button is facing up.
Insert the flat end of a spudger at a downward angle between the top edge of the front and rear shells, near the viewfinder.
Push your spudger into the gap and lower it towards the back of the camera to pry up the front shell and release the first clip.
Repeat the process on the other side of the camera to release the second clip.
Firmly secure the main body of the camera with one hand, and use your free hand to grip the front shell.
Rotate the bottom edge of the front shell upwards to separate it from the camera and remove it.
Firmly push the front shell back onto the camera to engage the clips.
Check around the perimeter of the shell seam and make sure there are no gaps. If there are, firmly press the shells together to engage the clip near the gap.
