はじめに
This guide will walk you through the steps of replacing the battery on your Polaroid Cube. Make sure the device is completely powered off before disassembly, and that you have all of the required tools.
必要な工具と部品
10 の人々がこのガイドを完成させました。
13 件のコメント
Any idea where to find the replacement batteries?
hooverhogg - 返信
Well described! Need to buy a replacement battery though but I have no idea about the specs of the battery. Any information?
Fuji 402424 Lithium ion (Pouch)battery 240mA 4.8V Can’t find it. Can anyone help with a source?
the cube requires a two-pack battery which has a single plug for both of them and so they have to be wired together in just the right way to be able to fit inside the cube. i guess it's not possible to buy replacement batt. and paying minimum $16 for it? u could just buy a new one for too close to $16. or a used one.
Podrías mandar enlace de compra? Link gracias marin_zgz_@hotmail.com .batería Polaroid cube
Any advice on where to buy the battery?
oldturkey03 was kind enough to give us the name of this small battery: Fuji 402424 Lithium ion (Pouch)battery 240mA 4.8V. His detailed answer is right about Polaroid cube battery type. Anyone knows it?
However, I tried to find a place to buy it from and no one seems to sell it. At least, no one ebay and not even on aliexpress.
Podrías mandar enlace de compra el link de las baterías de la polaroid cube . Marin_zgz_@ hotmail.com
Is this advice for Polaroid Cube+edition?
i need batter money how mach
Hany salah - 返信
I can only find 3.7v versions available, and after watching a repair video using similar replacements, they appear to work!
