メインコンテンツにスキップ
Polaroid A10 Speakers Replacement
必要な工具と部品
  1. Polaroid A10 Speakers Replacement, Back Cover: 手順 1、 3の画像 1 Polaroid A10 Speakers Replacement, Back Cover: 手順 1、 3の画像 2 Polaroid A10 Speakers Replacement, Back Cover: 手順 1、 3の画像 3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Speakers Replacement, Speakers: 手順 2、 1の画像 1
    • The speakers are located on the bottom of the device, below the battery and adjacent to the motherboard.
  3. Polaroid A10 Speakers Replacement: 手順 3、 3の画像 1 Polaroid A10 Speakers Replacement: 手順 3、 3の画像 2 Polaroid A10 Speakers Replacement: 手順 3、 3の画像 3
    • Using the Phillips #000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
    • Carefully remove the speakers from original position without pulling out the wires.
  4. Polaroid A10 Speakers Replacement: 手順 4、 1の画像 1
    • Using the soldering tool, remove the two small black wires and two small red wires from the motherboard.
    • The wire connections are located on the motherboard next to the corner of the battery closest to the motherboard.
    • Removal and installation of wires requires soldering. Here's a helpful link to assist you with great soldering techniques.
  5. Polaroid A10 Speakers Replacement: 手順 5、 1の画像 1
    • Gently lift the speakers up and out of the device.
終わりに
作成者
3人の作成者と共同で作成されました。
Koby
メンバー登録日: 01/22/15
104 ポイント
1ガイドが承認済み
チーム
UW Tacoma, Team 3-3, Rose Winter 2015 UW Tacoma, Team 3-3, Rose Winter 2015人のメンバー
UWT-ROSE-W15S3G3
4 メンバー
12のガイドは作成済み
3 件のコメント
This is not what I meant I wanted to know what to do if the wires came out of the
amirahoresanwo - 返信
If the wires and out of the
amirahoresanwo - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 255
