メインコンテンツにスキップ
Polaroid A10 Motherboard Replacement
必要な工具と部品
  1. Polaroid A10 Motherboard Replacement, Back Cover: 手順 1、 3の画像 1 Polaroid A10 Motherboard Replacement, Back Cover: 手順 1、 3の画像 2 Polaroid A10 Motherboard Replacement, Back Cover: 手順 1、 3の画像 3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Motherboard Replacement, Motherboard: 手順 2、 3の画像 1 Polaroid A10 Motherboard Replacement, Motherboard: 手順 2、 3の画像 2 Polaroid A10 Motherboard Replacement, Motherboard: 手順 2、 3の画像 3
    • Take off yellow tapes that are surrounding the motherboard.
    • Use the plastic opening tools to disconnect the three ribbon cables: battery, screen, and volume/power buttons.
  3. Polaroid A10 Motherboard Replacement: 手順 3、 3の画像 1 Polaroid A10 Motherboard Replacement: 手順 3、 3の画像 2 Polaroid A10 Motherboard Replacement: 手順 3、 3の画像 3
    • Using the Phillips #000 screwdriver, remove the four 5 mm screws located in the picture by rotating the screw counter-clockwise.
  4. Polaroid A10 Motherboard Replacement: 手順 4、 2の画像 1 Polaroid A10 Motherboard Replacement: 手順 4、 2の画像 2
    • Use the soldering tool to unsolder the two bigger metals from the wires of the battery.
    • Use the same soldering tool to unsolder the four smaller metals from the wires of the speakers.
    • Use the same soldering tool to unsolder the ground wire.
    • Removal and installation of wires requires soldering. Here's a helpful link to assist you with great soldering techniques.
  5. Polaroid A10 Motherboard Replacement: 手順 5、 3の画像 1 Polaroid A10 Motherboard Replacement: 手順 5、 3の画像 2 Polaroid A10 Motherboard Replacement: 手順 5、 3の画像 3
    • Gently lift the motherboard up and out of the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Tracie
メンバー登録日: 01/22/15
119 ポイント
1ガイドが承認済み
チーム
UW Tacoma, Team 3-3, Rose Winter 2015 UW Tacoma, Team 3-3, Rose Winter 2015人のメンバー
UWT-ROSE-W15S3G3
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 589
