メインコンテンツにスキップ
Polar Wind 8" High Velocity Fan Blades Replacement
必要な工具と部品
  1. Polar Wind 8" High Velocity Fan Blades Replacement, Fan Blades: 手順 1、 2の画像 1 Polar Wind 8" High Velocity Fan Blades Replacement, Fan Blades: 手順 1、 2の画像 2
    • Use a Y000 tri-point screwdriver to remove four screws from the backside of your the fan, turning counterclockwise.
    • Caution: Ensure your Polar Wind fan is shut OFF and unplugged before proceeding to avoid injury.
  2. Polar Wind 8" High Velocity Fan Blades Replacement: 手順 2、 2の画像 1 Polar Wind 8" High Velocity Fan Blades Replacement: 手順 2、 2の画像 2
    • Separate the cover from the back with your hands and set aside.
  3. Polar Wind 8" High Velocity Fan Blades Replacement: 手順 3、 2の画像 1 Polar Wind 8" High Velocity Fan Blades Replacement: 手順 3、 2の画像 2
    • Use a Y000 tri-point screwdriver to remove the two screws from under the fan blades, turning counterclockwise.
  4. Polar Wind 8" High Velocity Fan Blades Replacement: 手順 4、 3の画像 1 Polar Wind 8" High Velocity Fan Blades Replacement: 手順 4、 3の画像 2 Polar Wind 8" High Velocity Fan Blades Replacement: 手順 4、 3の画像 3
    • Carefully remove the fan blades by holding the base and lifting it up out of the motor.
    • There are two bands loosely attached to the bottom of the rod. Do not misplace the bands.
  5. Polar Wind 8" High Velocity Fan Blades Replacement: 手順 5、 3の画像 1 Polar Wind 8" High Velocity Fan Blades Replacement: 手順 5、 3の画像 2 Polar Wind 8" High Velocity Fan Blades Replacement: 手順 5、 3の画像 3
    • Firmly grasp the base of the blades, pushing it down and turning clockwise to slide down to the base of the rod.
    • Use a pair of pliers to remove the center disk by pinching the rim and pulling upwards.
    • Once it is loosened, squeeze the bottom of the disk and the tip of the rod between your pliers to more easily remove the disk.
    • The disk may be difficult to remove. Using lube may help slide it off more easily, but it is not required.
  6. Polar Wind 8" High Velocity Fan Blades Replacement: 手順 6、 3の画像 1 Polar Wind 8" High Velocity Fan Blades Replacement: 手順 6、 3の画像 2 Polar Wind 8" High Velocity Fan Blades Replacement: 手順 6、 3の画像 3
    • Once removed, set the center disk aside.
    • Firmly grasp the base of the fan blades, pulling upwards and turning counterclockwise.
    • Set old blades aside to be recycled later, and replace with the new blades.
    • Once you begin to reassemble your device, push the disk back onto the rod using your hand, then use the pliers to pull it down the rest of the way, until there is at least 1/4" between the disk and tip of the rod.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Aiden Peltier
メンバー登録日: 03/15/21
169 ポイント
1ガイドが承認済み
チーム
コメント 1 件
How (where) can I purchase a "center disc" from? I wish I seen this info before I disassembled it incorrectly. **(blade cracked off, so I cut broken area off by doing so bent center disc. SO I need to find where purchase a replacement blade & center disc. Thanks.
Djames ZW - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 19
今までの合計 1,741
