メインコンテンツにスキップ
Poin2 Chromebook 11 Speaker Replacement
必要な工具と部品
  1. Poin2 Chromebook 11 Speaker Replacement, Battery: 手順 1、 2の画像 1 Poin2 Chromebook 11 Speaker Replacement, Battery: 手順 1、 2の画像 2
    • Power down the Poin2 Chromebook 11 and disconnect the power adapter.
    • Close the Chromebook and position it with the base facing up.
    • Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
    • Poin2 Chromebook 11 does not have screws under its rubber feet at the base.
  2. Poin2 Chromebook 11 Speaker Replacement: 手順 2、 3の画像 1 Poin2 Chromebook 11 Speaker Replacement: 手順 2、 3の画像 2 Poin2 Chromebook 11 Speaker Replacement: 手順 2、 3の画像 3
    • Insert a 1cm-wide plastic opening tool between the base and top frame.
    • Applying pressure up and down with the tool may be necessary. When you hear a "click," this indicates the separation of the frame.
    • Pry (up and down) around the entire border of the Chromebook to separate.
    • Use your hands to gently lift the base away from the frame.
  3. Poin2 Chromebook 11 Speaker Replacement: 手順 3、 3の画像 1 Poin2 Chromebook 11 Speaker Replacement: 手順 3、 3の画像 2 Poin2 Chromebook 11 Speaker Replacement: 手順 3、 3の画像 3
    • Disconnect the white 8-wire battery connector from the motherboard using a spudger to push the two L-shaped clips out of the port.
    • The connector is a tight fit and requires careful pressure for release.
  4. Poin2 Chromebook 11 Speaker Replacement: 手順 4、 2の画像 1 Poin2 Chromebook 11 Speaker Replacement: 手順 4、 2の画像 2
    • Remove the six 4mm screws using a Phillips #0 screwdriver.
  5. Poin2 Chromebook 11 Speaker Replacement: 手順 5、 1の画像 1
    • Lift the battery from the frame.
  6. Poin2 Chromebook 11 Speaker Replacement, Speakers: 手順 6、 2の画像 1 Poin2 Chromebook 11 Speaker Replacement, Speakers: 手順 6、 2の画像 2
    • Unplug the black speaker cable from the lower, left side of the motherboard.
  7. Poin2 Chromebook 11 Speaker Replacement: 手順 7、 3の画像 1 Poin2 Chromebook 11 Speaker Replacement: 手順 7、 3の画像 2 Poin2 Chromebook 11 Speaker Replacement: 手順 7、 3の画像 3
    • Use the opening tool to pry the two speakers away from the frame.
    • An adhesive strip attaches each speaker to the frame. The speakers should pull away with moderate force.
  8. Poin2 Chromebook 11 Speaker Replacement: 手順 8、 2の画像 1 Poin2 Chromebook 11 Speaker Replacement: 手順 8、 2の画像 2
    • Detach the speaker cord from the hooks holding it to the frame and lift the speakers away.
終わりに
作成者
3人の作成者と共同で作成されました。
Whitney Lunny
メンバー登録日: 10/05/17
155 ポイント
1ガイドが承認済み
チーム
Portland State University, Team S1-G3, Romaine Spring 2018 Portland State University, Team S1-G3, Romaine Spring 2018人のメンバー
PSUN-ROMAINE-S18S1G3
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 226
