メインコンテンツにスキップ
Poin2 Chromebook 11 Charging Port Replacement
必要な工具と部品
  1. Poin2 Chromebook 11 Charging Port Replacement, Battery: 手順 1、 2の画像 1 Poin2 Chromebook 11 Charging Port Replacement, Battery: 手順 1、 2の画像 2
    • Power down the Poin2 Chromebook 11 and disconnect the power adapter.
    • Close the Chromebook and position it with the base facing up.
    • Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
    • Poin2 Chromebook 11 does not have screws under its rubber feet at the base.
  2. Poin2 Chromebook 11 Charging Port Replacement: 手順 2、 3の画像 1 Poin2 Chromebook 11 Charging Port Replacement: 手順 2、 3の画像 2 Poin2 Chromebook 11 Charging Port Replacement: 手順 2、 3の画像 3
    • Insert a 1cm-wide plastic opening tool between the base and top frame.
    • Applying pressure up and down with the tool may be necessary. When you hear a "click," this indicates the separation of the frame.
    • Pry (up and down) around the entire border of the Chromebook to separate.
    • Use your hands to gently lift the base away from the frame.
  3. Poin2 Chromebook 11 Charging Port Replacement: 手順 3、 3の画像 1 Poin2 Chromebook 11 Charging Port Replacement: 手順 3、 3の画像 2 Poin2 Chromebook 11 Charging Port Replacement: 手順 3、 3の画像 3
    • Disconnect the white 8-wire battery connector from the motherboard using a spudger to push the two L-shaped clips out of the port.
    • The connector is a tight fit and requires careful pressure for release.
  4. Poin2 Chromebook 11 Charging Port Replacement: 手順 4、 2の画像 1 Poin2 Chromebook 11 Charging Port Replacement: 手順 4、 2の画像 2
    • Remove the six 4mm screws using a Phillips #0 screwdriver.
  5. Poin2 Chromebook 11 Charging Port Replacement: 手順 5、 1の画像 1
    • Lift the battery from the frame.
  6. Poin2 Chromebook 11 Charging Port Replacement, Charging Port: 手順 6、 2の画像 1 Poin2 Chromebook 11 Charging Port Replacement, Charging Port: 手順 6、 2の画像 2
    • The changing port is located on the upper-right corner of the computer.
    • Disconnect the charging port from the motherboard using a spudger to push the 4-wire connector out from the port.
  7. Poin2 Chromebook 11 Charging Port Replacement: 手順 7、 2の画像 1 Poin2 Chromebook 11 Charging Port Replacement: 手順 7、 2の画像 2
    • Remove silver tape covering hinge.
  8. Poin2 Chromebook 11 Charging Port Replacement: 手順 8、 2の画像 1 Poin2 Chromebook 11 Charging Port Replacement: 手順 8、 2の画像 2
    • The metal hinge at the top right corner must be lifted to access the charging port.
    • Use a Phillips #0 screwdriver and remove the two 7mm screws from the hinge.
  9. Poin2 Chromebook 11 Charging Port Replacement: 手順 9、 1の画像 1
    • Pry the metal hinge up, until it sits perpendicular to the motherboard.
    • The metal hinge is a tight fit and requires careful strength when lifting.
  10. Poin2 Chromebook 11 Charging Port Replacement: 手順 10、 2の画像 1 Poin2 Chromebook 11 Charging Port Replacement: 手順 10、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use tweezers to gently pull the charging port out of the frame.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jesse Johnson
メンバー登録日: 10/05/17
330 ポイント
2のガイドは作成済み
チーム
Portland State University, Team S4-G4, Romaine Spring 2018 Portland State University, Team S4-G4, Romaine Spring 2018人のメンバー
PSUN-ROMAINE-S18S4G4
1 メンバー
4のガイドは作成済み
2 件のコメント
Great, Now where can I find this part to fix my laptop???
marrowii - 返信
where do I buy the new port???
rhena9 - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 20
過去 30 日: 117
今までの合計 7,125
