メインコンテンツにスキップ
Plugging in Shure SM58 XLR Cable
  1. Plugging in Shure SM58 XLR Cable, XLR Cable Plug In: 手順 1、 1の画像 1
    • Make sure you have a proper three pin XLR cable.
    • Grab the female end of the cable (plug with three holes).
  2. Plugging in Shure SM58 XLR Cable: 手順 2、 1の画像 1
    • Line up the pins in the end of the microphone (microphone connecter) with the holes in the XLR cable.
  3. Plugging in Shure SM58 XLR Cable: 手順 3、 1の画像 1
    • Once the pins are aligned, push the cable into the bottom end of the microphone. You should hear a click.
終わりに
To disconnect the cable from the microphone, follow the instructions in reverse.
13 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
nat coll
メンバー登録日: 09/27/12
642 ポイント
14のガイドは作成済み
チーム
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S7G53
5 メンバー
20のガイドは作成済み
21 件のコメント
When disconnecting the cable - press the little latch (pointing towards you in the last picture) to release and then pull the cable out.
harrywwc - 返信
Is this April's fool? XD
s6963172 - 返信
how i repair the PG48 the XLR conector moves in and out when the cable ar plugged. The conector male in the microphone have an screw but that one not works...
What am i do?
If you have an idea to the answer or any tip to resolve this trouble feel fre to tweet me.
@ Theradioholic
on
#Twitter
Santiago Morales - 返信
I know a few people who would see this and still screw it up.
jimboc - 返信
do it in reverse? you have to press the button though on the male end...
Michael Fox - 返信
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 40
過去 30 日: 124
今までの合計 67,364
