メインコンテンツにスキップ
PlayStation Vita Right Joystick Replacement
必要な工具と部品
  1. PlayStation Vita Right Joystick Replacement, Case Separation: 手順 1、 2の画像 1 PlayStation Vita Right Joystick Replacement, Case Separation: 手順 1、 2の画像 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Right Joystick Replacement: 手順 2、 3の画像 1 PlayStation Vita Right Joystick Replacement: 手順 2、 3の画像 2 PlayStation Vita Right Joystick Replacement: 手順 2、 3の画像 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Right Joystick Replacement: 手順 3、 2の画像 1 PlayStation Vita Right Joystick Replacement: 手順 3、 2の画像 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Right Joystick Replacement: 手順 4、 3の画像 1 PlayStation Vita Right Joystick Replacement: 手順 4、 3の画像 2 PlayStation Vita Right Joystick Replacement: 手順 4、 3の画像 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Right Joystick Replacement: 手順 5、 2の画像 1 PlayStation Vita Right Joystick Replacement: 手順 5、 2の画像 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Right Joystick Replacement: 手順 6、 1の画像 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Right Joystick Replacement: 手順 7、 1の画像 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Right Joystick Replacement: 手順 8、 1の画像 1
    • Separate the front and rear cases.
  9. PlayStation Vita Right Joystick Replacement, Wireless Card: 手順 9、 3の画像 1 PlayStation Vita Right Joystick Replacement, Wireless Card: 手順 9、 3の画像 2 PlayStation Vita Right Joystick Replacement, Wireless Card: 手順 9、 3の画像 3
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
  10. PlayStation Vita Right Joystick Replacement: 手順 10、 2の画像 1 PlayStation Vita Right Joystick Replacement: 手順 10、 2の画像 2
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Right Joystick Replacement: 手順 11、 2の画像 1 PlayStation Vita Right Joystick Replacement: 手順 11、 2の画像 2
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
  12. PlayStation Vita Right Joystick Replacement, Right Shoulder Button: 手順 12、 3の画像 1 PlayStation Vita Right Joystick Replacement, Right Shoulder Button: 手順 12、 3の画像 2 PlayStation Vita Right Joystick Replacement, Right Shoulder Button: 手順 12、 3の画像 3
    • Pry up the right shoulder button casing with a spudger and set it aside.
  13. PlayStation Vita Right Joystick Replacement: 手順 13、 1の画像 1
    • Remove the translucent, plastic right shoulder button cover.
  14. PlayStation Vita Right Joystick Replacement: 手順 14、 3の画像 1 PlayStation Vita Right Joystick Replacement: 手順 14、 3の画像 2 PlayStation Vita Right Joystick Replacement: 手順 14、 3の画像 3
    この手順で使用する道具:
    購入する
    • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
    • Using tweezers, slide the flex cable out of the socket.
  15. PlayStation Vita Right Joystick Replacement: 手順 15、 2の画像 1 PlayStation Vita Right Joystick Replacement: 手順 15、 2の画像 2
    • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
  16. PlayStation Vita Right Joystick Replacement, Right Button Board: 手順 16、 2の画像 1 PlayStation Vita Right Joystick Replacement, Right Button Board: 手順 16、 2の画像 2
    • Using the pointy end of a spudger, detach the antenna cable on the right button board.
    • Remove the antenna cable.
  17. PlayStation Vita Right Joystick Replacement: 手順 17、 2の画像 1 PlayStation Vita Right Joystick Replacement: 手順 17、 2の画像 2
    • Using a spudger, pry up and release the ZIF socket on the right button board.
    • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  18. PlayStation Vita Right Joystick Replacement: 手順 18、 3の画像 1 PlayStation Vita Right Joystick Replacement: 手順 18、 3の画像 2 PlayStation Vita Right Joystick Replacement: 手順 18、 3の画像 3
    この手順で使用する道具:
    購入する
    • Release the tab on the small flex cable socket by prying up the tab with a spudger.
    • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  19. PlayStation Vita Right Joystick Replacement: 手順 19、 3の画像 1 PlayStation Vita Right Joystick Replacement: 手順 19、 3の画像 2 PlayStation Vita Right Joystick Replacement: 手順 19、 3の画像 3
    • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
    • Remove the metal bracket, using a spudger as necessary to lift it out.
  20. PlayStation Vita Right Joystick Replacement: 手順 20、 3の画像 1 PlayStation Vita Right Joystick Replacement: 手順 20、 3の画像 2 PlayStation Vita Right Joystick Replacement: 手順 20、 3の画像 3
    • Use a spudger to free the right button board by prying up from the bottom right corner of board.
    • Gently lift the right button board out.
  21. PlayStation Vita Right Joystick Replacement, Right Joystick: 手順 21、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the two 5.0mm, blue screws from the right joystick.
  22. PlayStation Vita Right Joystick Replacement: 手順 22、 3の画像 1 PlayStation Vita Right Joystick Replacement: 手順 22、 3の画像 2 PlayStation Vita Right Joystick Replacement: 手順 22、 3の画像 3
    • Using a spudger, gently pry the joystick out of the back casing assembly.
終わりに
25 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Brittany McCrigler
メンバー登録日: 03/05/12
89,020 ポイント
131のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,299のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 35
過去 30 日: 129
今までの合計 29,258
