はじめに
This guide takes you through the process of installing the PS button on the PlayStation Vita.
必要な工具と部品
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Pry up the left shoulder button casing with a spudger.
Remove the left shoulder button casing.
Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader.
Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
7 の人々がこのガイドを完成させました。
