メインコンテンツにスキップ
PlayStation Vita Motherboard Replacement
必要な工具と部品
  1. PlayStation Vita Motherboard Replacement, Case Separation: 手順 1、 2の画像 1 PlayStation Vita Motherboard Replacement, Case Separation: 手順 1、 2の画像 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Motherboard Replacement: 手順 2、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 2、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 2、 3の画像 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Motherboard Replacement: 手順 3、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 3、 2の画像 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Motherboard Replacement: 手順 4、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 4、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 4、 3の画像 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Motherboard Replacement: 手順 5、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 5、 2の画像 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Motherboard Replacement: 手順 6、 1の画像 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Motherboard Replacement: 手順 7、 1の画像 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Motherboard Replacement: 手順 8、 1の画像 1
    • Separate the front and rear cases.
  9. PlayStation Vita Motherboard Replacement, Wireless Card: 手順 9、 3の画像 1 PlayStation Vita Motherboard Replacement, Wireless Card: 手順 9、 3の画像 2 PlayStation Vita Motherboard Replacement, Wireless Card: 手順 9、 3の画像 3
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
  10. PlayStation Vita Motherboard Replacement: 手順 10、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 10、 2の画像 2
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Motherboard Replacement: 手順 11、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 11、 2の画像 2
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
  12. PlayStation Vita Motherboard Replacement, Right Shoulder Button: 手順 12、 3の画像 1 PlayStation Vita Motherboard Replacement, Right Shoulder Button: 手順 12、 3の画像 2 PlayStation Vita Motherboard Replacement, Right Shoulder Button: 手順 12、 3の画像 3
    • Pry up the right shoulder button casing with a spudger and set it aside.
  13. PlayStation Vita Motherboard Replacement: 手順 13、 1の画像 1
    • Remove the translucent, plastic right shoulder button cover.
  14. PlayStation Vita Motherboard Replacement: 手順 14、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 14、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 14、 3の画像 3
    • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
    • Using tweezers, slide the flex cable out of the socket.
  15. PlayStation Vita Motherboard Replacement: 手順 15、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 15、 2の画像 2
    • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
  16. PlayStation Vita Motherboard Replacement, Right Button Board: 手順 16、 2の画像 1 PlayStation Vita Motherboard Replacement, Right Button Board: 手順 16、 2の画像 2
    • Using the pointy end of a spudger, detach the antenna cable on the right button board.
    • Remove the antenna cable.
  17. PlayStation Vita Motherboard Replacement: 手順 17、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 17、 2の画像 2
    • Using a spudger, pry up and release the ZIF socket on the right button board.
    • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  18. PlayStation Vita Motherboard Replacement: 手順 18、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 18、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 18、 3の画像 3
    • Release the tab on the small flex cable socket by prying up the tab with a spudger.
    • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  19. PlayStation Vita Motherboard Replacement: 手順 19、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 19、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 19、 3の画像 3
    • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
    • Remove the metal bracket, using a spudger as necessary to lift it out.
  20. PlayStation Vita Motherboard Replacement: 手順 20、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 20、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 20、 3の画像 3
    • Use a spudger to free the right button board by prying up from the bottom right corner of board.
    • Gently lift the right button board out.
  21. PlayStation Vita Motherboard Replacement, Left Shoulder Button: 手順 21、 3の画像 1 PlayStation Vita Motherboard Replacement, Left Shoulder Button: 手順 21、 3の画像 2 PlayStation Vita Motherboard Replacement, Left Shoulder Button: 手順 21、 3の画像 3
    • Pry up the left shoulder button casing with a spudger.
    • Remove the left shoulder button casing.
  22. PlayStation Vita Motherboard Replacement: 手順 22、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 22、 2の画像 2
    • Remove the translucent, plastic left shoulder button cover.
  23. PlayStation Vita Motherboard Replacement: 手順 23、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 23、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 23、 3の画像 3
    • Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
    • Be careful to not break off this small black tab!
    • Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
  24. PlayStation Vita Motherboard Replacement: 手順 24、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 24、 2の画像 2
    • Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
  25. PlayStation Vita Motherboard Replacement, Left Button Board: 手順 25、 2の画像 1 PlayStation Vita Motherboard Replacement, Left Button Board: 手順 25、 2の画像 2
    • Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader.
    • Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
  26. PlayStation Vita Motherboard Replacement: 手順 26、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 26、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 26、 3の画像 3
    • Use a spudger to release the tab between the SIM card reader and the back casing assembly.
    • Lift the SIM card reader off the back casing assembly.
  27. PlayStation Vita Motherboard Replacement: 手順 27、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 27、 2の画像 2
    • Release the plastic tab on the small flex cable socket by prying it up with a spudger.
    • Using tweezers, gently remove the small flex cable from the socket, and rest it out of the way.
  28. PlayStation Vita Motherboard Replacement: 手順 28、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 28、 2の画像 2
    • Use a spudger to lift up the tab on the large ZIF socket.
    • Gently pull the flex cable out of the ZIF socket, and rest it out of the way.
  29. PlayStation Vita Motherboard Replacement: 手順 29、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 29、 2の画像 2
    • Disconnect the white Wi-Fi antenna cable with a spudger.
    • Remove the Wi-Fi antenna cable.
  30. PlayStation Vita Motherboard Replacement: 手順 30、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 30、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 30、 3の画像 3
    • Using a Phillips #00 screwdriver, remove the six screws on the two metal brackets:
    • Two 5.0mm, blue screws on the L-bracket securing the upper left button board to the motherboard.
    • Four 5.0mm, blue screws on the square bracket securing the lower left button board to the motherboard.
  31. PlayStation Vita Motherboard Replacement: 手順 31、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 31、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 31、 3の画像 3
    • Starting from the upper left corner, use a spudger to pry up and remove the left button board.
  32. PlayStation Vita Motherboard Replacement, Motherboard: 手順 32、 2の画像 1 PlayStation Vita Motherboard Replacement, Motherboard: 手順 32、 2の画像 2
    • Using the pointy end of a spudger, pry up and release the GPS antenna cable from the motherboard.
    • Remove the GPS antenna cable.
  33. PlayStation Vita Motherboard Replacement: 手順 33、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 33、 2の画像 2
    • Release the camera flex cable socket by prying up on the tab with a spudger.
  34. PlayStation Vita Motherboard Replacement: 手順 34、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 34、 2の画像 2
    • Using a spudger, gently pry up on the camera.
    • Work your way under the camera and along the camera flex cable, using the spudger to peel away the adhesive, freeing the camera.
  35. PlayStation Vita Motherboard Replacement: 手順 35、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 35、 2の画像 2
    • Carefully lift and remove the camera, sliding the flex cable out of the open connector socket.
  36. PlayStation Vita Motherboard Replacement: 手順 36、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 36、 2の画像 2
    • Using a Phillips #00 screwdriver, remove the 6.3mm screw beneath the camera.
    • Lift and remove the metal camera bracket.
  37. PlayStation Vita Motherboard Replacement: 手順 37、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 37、 2の画像 2
    • With the help of a spudger, lift and release the tab on the blue flex cable socket.
  38. PlayStation Vita Motherboard Replacement: 手順 38、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 38、 2の画像 2
    • Using tweezers, gently pull the blue power flex cable out of the socket; rest it out of the way.
  39. PlayStation Vita Motherboard Replacement: 手順 39、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the two pink, 4.4mm screws securing the motherboard.
  40. PlayStation Vita Motherboard Replacement: 手順 40、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 40、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 40、 3の画像 3
    • Gently peel the rubber tab of the game port cover off the plastic casing pins.
    • Remove the game port cover.
  41. PlayStation Vita Motherboard Replacement: 手順 41、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 41、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 41、 3の画像 3
    • Gently peel the rubber tab of the accessory port cover off the plastic casing pins.
    • Remove the accessory port cover.
  42. PlayStation Vita Motherboard Replacement: 手順 42、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 42、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 42、 3の画像 3
    • Starting at the upper right hand corner, use a spudger to gently lift the motherboard out of the casing assembly.
    • The motherboard is still attached to the casing by a connector on the back of the motherboard. Do not pull the motherboard all the way out, or you may damage the connector.
  43. PlayStation Vita Motherboard Replacement: 手順 43、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 43、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 43、 3の画像 3
    • Lift the motherboard out and identify the OLED connector still attaching the motherboard to the casing.
    • Holding the Vita on its side, use a spudger to gently pry off the OLED connector from the motherboard.
    • Be sure to hold the motherboard while you release the connector as this will free the motherboard. If you are not holding the motherboard, it will fall.
  44. PlayStation Vita Motherboard Replacement: 手順 44、 1の画像 1
    • Completely separate the motherboard from the case. Remove the case.
  45. PlayStation Vita Motherboard Replacement: 手順 45、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 45、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 45、 3の画像 3
    • Starting at the right side, gently lift and remove the black casing that once held the camera.
  46. PlayStation Vita Motherboard Replacement: 手順 46、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 46、 2の画像 2
    • Using a spudger, release the tab on the ZIF connector located above the two screw posts where the wireless card once was.
  47. PlayStation Vita Motherboard Replacement: 手順 47、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 47、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 47、 3の画像 3
    • Gently pull the flex cable out of the ZIF connector, and remove it.
  48. PlayStation Vita Motherboard Replacement: 手順 48、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 48、 2の画像 2
    • Release the tab on the large ZIF connector on the right side of the motherboard by lifting the tab with a spudger.
  49. PlayStation Vita Motherboard Replacement: 手順 49、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 49、 2の画像 2
  50. PlayStation Vita Motherboard Replacement: 手順 50、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 50、 2の画像 2
    • Using a spudger, release the small ZIF connector on the right side of the motherboard.
  51. PlayStation Vita Motherboard Replacement: 手順 51、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 51、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 51、 3の画像 3
    • Gently pull the flex cable out of the small ZIF connector, and remove it.
  52. PlayStation Vita Motherboard Replacement: 手順 52、 2の画像 1 PlayStation Vita Motherboard Replacement: 手順 52、 2の画像 2
    • Flip the motherboard over.
    • With the help of a spudger, pry up and release the tab of the rear camera flex cable connector.
  53. PlayStation Vita Motherboard Replacement: 手順 53、 3の画像 1 PlayStation Vita Motherboard Replacement: 手順 53、 3の画像 2 PlayStation Vita Motherboard Replacement: 手順 53、 3の画像 3
    • Gently pull the rear camera out of the connector and remove it.
  54. PlayStation Vita Motherboard Replacement: 手順 54、 1の画像 1
    • The motherboard remains.
終わりに
41 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Brittany McCrigler
メンバー登録日: 03/05/12
88,580 ポイント
132のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
136 メンバー
15,118のガイドは作成済み
11 件のコメント
in steps 2&3, bottom is top and top is bottom
Samir Al Jubori - 返信
it should be noted that the memory card should always be taken out before separating the case. I just broke my memory card slot by having a card in there while I was opening the case, there's a tiny bit of overhang that will pull the slot off the motherboard.
bryandodson - 返信
does anyone know what firmware version the motherboard comes with?
riddochj - 返信
These are used Motherboards. You could get a motherboards with a random FW version.
Raheem -
Okay My original Motherboard power connector broke. So nothing was wrong with it except the Power connector.
My first buy of the Motherboard screen connector broke off.
The Replacement works well, however the Touch input isn't working, unless I restore the device. After a certain amount of time it becomes unresponsive.
Do anyone have a fix before I get a 3rd replacement.
Raheem - 返信
コメントを追加
統計データ:
過去 24時間: 14
過去 7 日: 80
過去 30 日: 313
今までの合計 61,353
