メインコンテンツにスキップ
PlayStation Vita Left Shoulder Button Replacement
必要な工具と部品
  1. PlayStation Vita Left Shoulder Button Replacement, Case Separation: 手順 1、 2の画像 1 PlayStation Vita Left Shoulder Button Replacement, Case Separation: 手順 1、 2の画像 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Left Shoulder Button Replacement: 手順 2、 3の画像 1 PlayStation Vita Left Shoulder Button Replacement: 手順 2、 3の画像 2 PlayStation Vita Left Shoulder Button Replacement: 手順 2、 3の画像 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Left Shoulder Button Replacement: 手順 3、 2の画像 1 PlayStation Vita Left Shoulder Button Replacement: 手順 3、 2の画像 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Left Shoulder Button Replacement: 手順 4、 3の画像 1 PlayStation Vita Left Shoulder Button Replacement: 手順 4、 3の画像 2 PlayStation Vita Left Shoulder Button Replacement: 手順 4、 3の画像 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Left Shoulder Button Replacement: 手順 5、 2の画像 1 PlayStation Vita Left Shoulder Button Replacement: 手順 5、 2の画像 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Left Shoulder Button Replacement: 手順 6、 1の画像 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Left Shoulder Button Replacement: 手順 7、 1の画像 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Left Shoulder Button Replacement: 手順 8、 1の画像 1
    • Separate the front and rear cases.
  9. PlayStation Vita Left Shoulder Button Replacement, Left Shoulder Button: 手順 9、 3の画像 1 PlayStation Vita Left Shoulder Button Replacement, Left Shoulder Button: 手順 9、 3の画像 2 PlayStation Vita Left Shoulder Button Replacement, Left Shoulder Button: 手順 9、 3の画像 3
    • Pry up the left shoulder button casing with a spudger.
    • Remove the left shoulder button casing.
  10. PlayStation Vita Left Shoulder Button Replacement: 手順 10、 2の画像 1 PlayStation Vita Left Shoulder Button Replacement: 手順 10、 2の画像 2
    • Remove the translucent, plastic left shoulder button cover.
  11. PlayStation Vita Left Shoulder Button Replacement: 手順 11、 3の画像 1 PlayStation Vita Left Shoulder Button Replacement: 手順 11、 3の画像 2 PlayStation Vita Left Shoulder Button Replacement: 手順 11、 3の画像 3
    • Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
    • Be careful to not break off this small black tab!
    • Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
  12. PlayStation Vita Left Shoulder Button Replacement: 手順 12、 2の画像 1 PlayStation Vita Left Shoulder Button Replacement: 手順 12、 2の画像 2
    • Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Brittany McCrigler
メンバー登録日: 03/05/12
89,014 ポイント
131のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 15
過去 30 日: 67
今までの合計 12,487
