はじめに
This guide takes you through the process of installing the left button board. This board controls the directional pad (D-pad) and PS button.
必要な工具と部品
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
Free the battery cable by gently prying up on the connection with a spudger.
Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
Yea I messed up there too. Is there a way to fix it?
This component was far more stubborn than the screen connector when it came to removal. I opted for a smaller tool than the spudger (small flat-head) and managed to disconnect it after determining the best bit size for the job. Screwdriver is metal, obviously, so being gentle helps to avoid damaging anything.
broke the white part
Pry up the left shoulder button casing with a spudger.
Remove the left shoulder button casing.
Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader.
Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
Este paso NO es necesario si tu PSVita no tiene lector de tarjeta SIM. Ve directamente al paso 15.
Using a Phillips #00 screwdriver, remove the six screws on the two metal brackets:
Two 5.0mm, blue screws on the L-bracket securing the upper left button board to the motherboard.
Four 5.0mm, blue screws on the square bracket securing the lower left button board to the motherboard.
6 の人々がこのガイドを完成させました。
3 件のコメント
good idea but i need help with the big fat one on the left because it went into water by an accsident and its not moving and its like locked or like jammed. I put it in the boiler for a while and i took it out after then it still was jammed locked.
please can you tell me how to fix the big fat button on the left because water went in it and i tryed putting it in the boiler for a while then i took it out and the button was still not working it like jammed locked it dosn't work. PLEEEEEEAAAAASSSSEEE HEEELLLPPP MEEEEEE!!!!!!!!!!!!!!!!!!
Make a video of it please!!!!
